Marlin kimbra e ripresa stampa dopo perdita di corrente October 09, 2017 05:43PM |
Re: Marlin kimbra e ripresa stampa dopo perdita di corrente October 09, 2017 06:07PM |
/************************************************************************** ***************************** Power Check ******************************** ************************************************************************** * * * A triggered when the pin detects lack of voltage * * Setting POWER CHECK PIN in Configuration_Pins.h * * * **************************************************************************/ //#define POWER_CHECK // Set true or false should assigned #define POWER_CHECK_LOGIC false // Uncomment to use internal pullup for pin if the sensor is defined. //#define POWER_CHECK_PULLUP /**************************************************************************/
