MK4Due and new Arduino Due shield RURAMPS4D
November 08, 2017 03:27AM
I developed a new shield for arduino due RURAMPS4D.
http://3dtoday.ru/blogs/svs0724/ruramps4d-ramps-for-adruino-due-the-pilot-shipment-available-for-zack/
I tried different firmware, and on Mk4DUE 4.3.2 encountered a problem:
The HotEnd0, controlled from pin 13 arduino, will not turn on. On other firmware everything works.
Here is the pinout file of the board
1410.h
Can anyone suggest what might be the problem?
Re: MK4Due and new Arduino Due shield RURAMPS4D
November 08, 2017 05:11AM
Test it with last dev please..
My Blog - My Thingiverse
November 08, 2017 07:13AM
OK, I'll check in the evening
November 08, 2017 09:50AM
MagoKimbra
I find this:
...When the SAM3X8E's internal AD15 input is enabled to sample the chips internal temp sensor, the digital output capability of SAM3X8E pin PB27 is disabled (Due pin D13). More specifically, to internally route the analog signal from the internal mcu temp sensor to the internal AD15 input, the internal digital output line for PB27 is usurped, rendering PB27 useless as a digital output....
Is there a problem with this? I should disable mcu temp sensor?
November 08, 2017 04:45PM
Azz ok i undestand the problem..
November 08, 2017 04:50PM
Ok I fixed it try now with last commit..
November 08, 2017 05:00PM
OT... mi stupisce e affascina quando uno parla in gaelico e l' altro.... capisce.... forte il nostro Mago....thumbs up
November 08, 2017 05:07PM
Gaelico?? che lingua รจ?? Io ho solo capito SAM3X8E's internal ADC15 e pin 13... grinning smiley
November 09, 2017 02:37AM
MagoKimbra
Thank you. Another question: RUMAMPS4D has already begun to be sold in Russia, can you add it to the list of boards supported by MK4Doue. If so, what is required of me?
November 09, 2017 05:53AM
Yes my pleasure... Send me the file pin when you have finish your testing..
November 09, 2017 06:38AM
MagoKimbra
Ok, Thanks
