MarlinKimbra 4.3.6 e autobedlevel May 27, 2018 05:27PM |
Re: MarlinKimbra 4.3.6 e autobedlevel May 28, 2018 02:49AM |
Re: MarlinKimbra 4.3.6 e autobedlevel May 28, 2018 03:33AM |
Re: MarlinKimbra 4.3.6 e autobedlevel May 28, 2018 04:36AM |
#define Z_CLEARANCE_DEPLOY_PROBE 10 // Z Clearance for Deploy/Stow #define Z_CLEARANCE_BETWEEN_PROBES 5 // Z Clearance between probe points
// Offsets to the probe relative to the nozzle tip (Nozzle - Probe) // X and Y offsets MUST be INTEGERS // // +-- BACK ---+ // | | // L | (+) P | R <-- probe (10,10) // E | | I // F | (-) N (+) | G <-- nozzle (0,0) // T | | H // | P (-) | T <-- probe (-10,-10) // | | // O-- FRONT --+ // (0,0) #define X_PROBE_OFFSET_FROM_NOZZLE 0 // X offset: -left [of the nozzle] +right #define Y_PROBE_OFFSET_FROM_NOZZLE 0 // Y offset: -front [of the nozzle] +behind #define Z_PROBE_OFFSET_FROM_NOZZLE -1 // Z offset: -below [of the nozzle] (always negative!)
// Probe Raise options provide clearance for the probe to deploy, stow, and travel. #define Z_PROBE_DEPLOY_HEIGHT 15 // Z position for the probe to deploy/stow #define Z_PROBE_BETWEEN_HEIGHT 5 // Z position for travel between points #define Z_PROBE_AFTER_PROBING 0 // Z position after probing is done
#define GRID_MAX_POINTS_X 3 #define GRID_MAX_POINTS_Y 3 #define LEFT_PROBE_BED_POSITION 35 #define RIGHT_PROBE_BED_POSITION 190 #define FRONT_PROBE_BED_POSITION 31 #define BACK_PROBE_BED_POSITION 190 #define MIN_PROBE_EDGE 10 //#define PROBE_Y_FIRST //#define ABL_BILINEAR_SUBDIVISION #define BILINEAR_SUBDIVISIONS 3 #define PROBE_PT_1_X 35 #define PROBE_PT_1_Y 190 #define PROBE_PT_2_X 35 #define PROBE_PT_2_Y 31 #define PROBE_PT_3_X 190 #define PROBE_PT_3_Y 31
"maxgridpointX": 3, "maxgridpointY": 3, "leftprobe": 35, "rightprobe": 190, "backprobe": 190, "frontprobe": 31, "Xprobe1": 35, "Yprobe1": 190, "Xprobe2": 35, "Yprobe2": 31, "Xprobe3": 190, "Yprobe3": 31,
/* Below you will find the configuration string, that created with Configurator tool online marlinkimbra.it ========== Start configuration string ========== {
Re: MarlinKimbra 4.3.6 e autobedlevel May 28, 2018 05:12AM |
Re: MarlinKimbra 4.3.6 e autobedlevel May 28, 2018 06:45AM |
Re: MarlinKimbra 4.3.6 e autobedlevel May 28, 2018 12:15PM |
Re: MarlinKimbra 4.3.6 e autobedlevel May 28, 2018 01:38PM |
Re: MarlinKimbra 4.3.6 e autobedlevel May 29, 2018 04:02AM |
Re: MarlinKimbra 4.3.6 e autobedlevel October 28, 2018 04:57AM |
Re: MarlinKimbra 4.3.6 e autobedlevel October 28, 2018 04:26PM |
