Problema su eeprom? February 06, 2019 04:29AM |
Re: Problema su eeprom? February 06, 2019 05:31AM |
Re: Problema su eeprom? February 06, 2019 06:12AM |
Re: Problema su eeprom? February 06, 2019 06:20AM |
Re: Problema su eeprom? February 06, 2019 06:24AM |
Re: Problema su eeprom? February 06, 2019 06:34AM |
Re: Problema su eeprom? February 06, 2019 02:47PM |
Re: Problema su eeprom? February 07, 2019 05:07AM |
10:37:28.060 : Printer reset detected - initalizing 10:37:28.060 : start 10:37:28.060 : Printer reset detected - initalizing 10:37:28.061 : start 10:37:28.086 : echo:echo:MK4duo_4.3.8 10:37:28.087 : echo:Last Updated: Feb 7 2019 10:32:52 | Author: (Trigun, V1trigun) 10:37:28.087 : echo:Compiled: Feb 7 2019 10:37:28.087 : echo:Free Memory: 3583 PlannerBufferBytes: 1184 10:37:28.265 : N1 M110*34 10:37:28.265 : N2 M115*36 10:37:28.265 : N3 M105*36 10:37:28.265 : N4 M114*35 10:37:28.265 : N5 M111 S6*98 10:37:28.265 : N6 T0*60 10:37:28.265 : N7 M20*22 10:37:28.270 : N8 M80*19 10:37:30.180 : ErrorD init fail 10:37:30.448 : echo:MKV61 Stored settings retrieved (375 bytes; crc 43305) 10:37:30.448 : Config: G21 ; Units in (mm) 10:37:30.448 : Configteps per unit: 10:37:30.448 : Config: M92 X80.400 Y80.420 Z395.000 T0 E95.900 10:37:30.449 : Config:Maximum feedrates (units/s): 10:37:30.449 : Config: M203 X100.000 Y100.000 Z5.000 T0 E100.000 10:37:30.449 : Config:Maximum Acceleration (units/s2): 10:37:30.449 : Config: M201 X1000 Y1000 Z50 T0 E5000 10:37:30.449 : Config:Acceleration (units/s2): P V T* R 10:37:30.449 : Config: M204 P2000.000 V2000.000 T0 R10000.000 10:37:30.449 : Config:Advanced: B S V 10:37:30.449 : Config: M205 B20000 S0.000 V0.000 10:37:30.449 : Config:Jerk: X Y Z T* E 10:37:30.450 : Config: M205 X10.000 Y10.000 Z0.400 T0 E5.000 10:37:30.450 : Config:Heater Sensor parameters: H P T A B C R L O: 10:37:30.450 : Config: M305 H0 P13 T1 A100000.0 B4092.0 C0.0000000000 R4700.0 L0 O0 10:37:30.450 : Config:Heater parameters: H P A B C L O U I T: 10:37:30.450 : Config: M306 H0 P10 A40 B230 C255 L5 O270 U1 I0 T0 10:37:30.450 : Config:Heater PID parameters: H P I D: 10:37:30.450 : Config: M301 H0 P18.82 I1.22 D72.83 10:37:30.450 : Config:Heater Sensor parameters: H P T A B C R L O: 10:37:30.452 : Config: M305 H-1 P14 T1 A100000.0 B4092.0 C0.0000000000 R4700.0 L0 O0 10:37:30.452 : Config:Heater parameters: H P A B C L O U I T: 10:37:30.453 : Config: M306 H-1 P8 A40 B230 C255 L5 O100 U1 I0 T0 10:37:30.453 : Config:Heater PID parameters: H P I D: 10:37:30.453 : Config: M301 H-1 P170.72 I12.79 D569.90 10:37:30.453 : Config:Fans: P U L X F I H T 10:37:30.453 : Config: M106 P0 U9 L0 X255 F250 I0 H-1 10:37:30.453 : Config:Endstops logic: 10:37:30.453 : Config: M123 X1 Y1 Z0 10:37:30.453 : Config:Endstops pullup: 10:37:30.453 : Config: M124 X1 Y1 Z1 10:37:30.453 : Config: M149 C ; Units in Celsius 10:37:30.453 : Configervo Angles: P L U: 10:37:30.454 : Config: M281 P0 L0 U0 10:37:30.454 : Config:Mesh Bed Leveling 10:37:30.454 : Config: M420 S0 10:37:30.454 : Configrobe Offset X Y Z, speed Fast and Slow [mm/min], Repetitions (mm): 10:37:30.454 : Config: M851 X0.000 Y0.000 Z-1.000 F1000 S500 R1 10:37:30.454 : Config:Material heatup parameters 10:37:30.454 : Config: M145 S0 H190 B60 F255 10:37:30.454 : Config: M145 S1 H240 B100 F255 10:37:30.454 : Config: M145 S2 H230 B60 F255 10:37:30.454 : Configtepper Direction 10:37:30.454 : Config: M569 X1 Y1 Z1 T0 E0 10:37:30.454 : Configtepper driver control 10:37:30.454 : Config: M569 D0 P0 R500000 10:37:30.455 : Stats: Total:65535, Finished:65535, Failed:0 10:37:30.455 : Stats: Total print time:136y 70d 6h 28m 15s, Longest job:136y 70d 6h 28m 15s 10:37:30.455 : Stats: Power on time:35m 19s 10:37:30.455 : Stats: Filament used:63389Km 65053m 65472cm 65528mm 10:37:30.674 : N9 M105*46 10:37:31.451 : Printer reset detected - initalizing 10:37:31.451 : start 10:37:31.451 : Printer reset detected - initalizing 10:37:31.451 : start 10:37:31.477 : echo:echo:MK4duo_4.3.8
Re: Problema su eeprom? February 07, 2019 09:24AM |
Re: Problema su eeprom? February 07, 2019 09:31AM |
Re: Problema su eeprom? February 07, 2019 09:50AM |
Re: Problema su eeprom? February 07, 2019 12:37PM |
