this is why you don't leave your printer unattended July 25, 2014 01:43AM |
Admin Registered: 12 years ago Posts: 1,063 |
Re: this is why you don't leave your printer unattended July 25, 2014 01:54AM |
Re: this is why you don't leave your printer unattended July 25, 2014 01:59AM |
A2
Great test.
I assume that was with a 12V, 40W heater cartridge, can you test a 20W?
Re: this is why you don't leave your printer unattended July 25, 2014 02:20AM |
Re: this is why you don't leave your printer unattended July 25, 2014 03:06AM |
Re: this is why you don't leave your printer unattended July 25, 2014 12:46PM |
Re: this is why you don't leave your printer unattended July 25, 2014 06:02PM |
LoboCNC
This makes me want to swap out the MOSFETs on my controller boards with OMNIFETs. These are smart MOSFETs from ST (eg: VNP10N06) with internal thermal shutdown which should help prevent most thermal runaway failures. There are still lots of other things that could fail and cause a fire, though...
One other thing I realized about your test - running a 12v, 40w cartridge at 19v actually ends up drawing about 100w, which is particularly dire. Probably lots of people do this, but 25w would seem ample for almost any hot-end. (My latest prototype hot-end has an average current draw of only about 6w while extruding.)
Anonymous User
Re: this is why you don't leave your printer unattended July 25, 2014 07:51PM |
Re: this is why you don't leave your printer unattended July 29, 2014 02:24PM |
Re: this is why you don't leave your printer unattended July 29, 2014 02:47PM |
Re: this is why you don't leave your printer unattended July 29, 2014 07:17PM |
BackEMF
Is there some protection in the software?
Something like:
If hotend is on
and temperature is less then 10C (in case the thermistor is disconnected)
then stop and shut down
though that still doesn’t protect from a thermistor that just doest touch the heater block.
Re: this is why you don't leave your printer unattended July 29, 2014 07:58PM |
BackEMF
Something like:
If hotend is on
I'm going to test how flammable my PLA is. The plastic in your video is that PLA or ABS?
Re: this is why you don't leave your printer unattended August 02, 2014 04:02AM |
Re: this is why you don't leave your printer unattended August 08, 2014 01:44PM |
thejollygrimreaper
i have done this test again one the 12v power supply and the wirewound 5.7ohms resistor seems pretty safe it topped out at 330c odd
https://www.youtube.com/watch?v=vVRwHwxNy7s
Re: this is why you don't leave your printer unattended August 08, 2014 06:21PM |
jaguarking11
thejollygrimreaper
I too am afraid of those ceramic heaters. Do you have a part number for the resistor? Or a place to buy it? I would not mind having 5-10 of them as spares.
Re: this is why you don't leave your printer unattended August 11, 2014 01:01AM |
thejollygrimreaper
Re: this is why you don't leave your printer unattended August 11, 2014 01:48AM |
greenman100
thejollygrimreaper
Why is this odd? Its 25 watts instead of 40w...
Re: this is why you don't leave your printer unattended August 11, 2014 02:02AM |
Re: this is why you don't leave your printer unattended August 11, 2014 02:03AM |
jaguarking11
It's not odd at all. Every element has its failure point or peak energy absorbtion. The wire wound stuff seems to be designed in a way that it won't start a fire. Instead it will self destruct. I suspect that has to do with the ignition point of a pcb. If I recall correctly that should be in the 400 to 500 centigrade range..... therefore it's designed to fail instead of ignite. At least that is my concmussion. As for them failing on a hot end. That has everything to do with the mounting.
Re: this is why you don't leave your printer unattended August 11, 2014 06:28AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: this is why you don't leave your printer unattended August 11, 2014 07:55AM |
nophead
I recommend vitreous enamel 6.8R resistors at 12V, [uk.farnell.com]. They top out at around 300C in a typical hot end simply because as the temperature increases the heat loss through conduction, convection and radiation increases, so at some temperature that equals the power in and it won't get any hotter. And they handle surface temperatures up to 450C so they don't fail even in a fault condition.
They have poor dimensional tolerance, so the hole needs to be quite a bit bigger than a typical resistor. Therefore they must be fixed in with something conductive to bridge the gap, such as exhaust putty.
I have never had one fail that was cemented in. I have had one fixed with kapton and one with silicone fail because they don't have a good thermal connection, so their surface can get a lot hotter.
J-Heads from hotends.com come with 5.6R silicone resistors. Although they are not as well suited I have never known one of those to fail either.
As they are shorter than cartridge heaters they allow a smaller heater block and don't stick out, so they are actually more efficient because less heat is wasted.
Re: this is why you don't leave your printer unattended August 11, 2014 08:09AM |
Re: this is why you don't leave your printer unattended August 11, 2014 04:44PM |
nophead
Cartridge heaters are supposed to be inserted into close tolerance smooth holes. When the expand they form a good thermal connection. How do you get that with oversized holes?
Re: this is why you don't leave your printer unattended August 19, 2014 02:31PM |
Re: this is why you don't leave your printer unattended August 19, 2014 05:00PM |
Re: this is why you don't leave your printer unattended February 17, 2015 09:32PM |
