Building Core XY Printer: need help deciding on what built March 19, 2015 09:11PM |
Re: Building Core XY Printer: need help deciding on what built March 19, 2015 11:49PM |
Re: Building Core XY Printer: need help deciding on what built March 20, 2015 03:46PM |
Re: Building Core XY Printer: need help deciding on what built March 21, 2015 01:19AM |
Re: Building Core XY Printer: need help deciding on what built March 21, 2015 02:11AM |
Re: Building Core XY Printer: need help deciding on what built March 21, 2015 07:39AM |
LarsK
Some designs have the tensioning where the belts terminate, again from Sdavi - I don't agree with him here. You should only need one tensioning point for each belt.
Re: Building Core XY Printer: need help deciding on what built March 21, 2015 11:00AM |
sdavi
LarsK
Actually, I only use one tensioning point for each belt, the motors are both now fixed. A previous iteration I did tension only by sliding the motor mounts, but found this to be a less accurate way to apply tension, especially when both belts ideally should have equal tension. I find it much easier to pluck both belts and tighten a screw for the tension until they sound the same.
Re: Building Core XY Printer: need help deciding on what built March 23, 2015 12:17AM |
Re: Building Core XY Printer: need help deciding on what built March 23, 2015 05:11AM |
Re: Building Core XY Printer: need help deciding on what built March 23, 2015 05:27AM |
J.A.C.
Ok, thank you for the comments, it guided me some decision making.
Now this my first "Idea" on my CoreXY. I did a quick sketchup to put my ideas on "paper".
I'd like any comments, I am willing to change and make it better as I go.
Now keep in mind that I was considering making it a Pulley Cable/wire Printer.
So here is a over look of the printer. I am putting all the electronics, motors and such on the side. I want to "Box" that, separated from the printer with a wall, and mount in some fan for extra cooling chamber (Like a computer tower). It also leaves me a easy access to everything.
[attachment 51576 My_corexy-test-01-01.jpg]
Now, the bed what drove me nuts at first, the concept is actually based from platform elevator system.
[attachment 51577 My_corexy-test-01-02.jpg][attachment 51578 My_corexy-test-01-03.jpg]
Now all this is really sketchy, but I wanted comments before I start making a real solid plan. I decided to center the motors for event stress on the cables and the pulley system.
[attachment 51582 My_corexy-test-01-04.jpg]
The fun part about cable, is that do not have to stay "flat", Also, for the tension I am planning to have my hooks on nuts for putting the right tension on the cables.
[attachment 51581 My_corexy-test-01-05.jpg][attachment 51580 My_corexy-test-01-06.jpg][attachment 51579 My_corexy-test-01-07.jpg]
Depending on what rail system I take, the print bed will be in the 14x16x18, but I will be happy with 12x14x16 , I left a lot of space so I have room to go in without worrying to much.
The bed will hold by 4 rail for a even and solid, I am not planning on putting a heated bed for now, and if I do, good chances it will be home made.
I am considering putting the extruder on the frame, keep everything as light as I can.
But as I said, I want to consider all the comments of ya guy's.
I started a BOM list, because I making/have most everything that is frame related, the price is keep low. I want to go with popularize systems/motors, and good quality, this should cost me in the 400$
Re: Building Core XY Printer: need help deciding on what built March 23, 2015 06:14AM |
Re: Building Core XY Printer: need help deciding on what built March 23, 2015 06:30AM |
Re: Building Core XY Printer: need help deciding on what built March 23, 2015 07:29AM |
Re: Building Core XY Printer: need help deciding on what built March 23, 2015 07:53AM |
J.A.C.
(ps: yes this is my first printer)
-Cartesian, ahha, did not know that. Am I still in the the right Forum sector? ^_^ I was thinking of going with a cable system (Cartesian), but if that system is flawed, I would like to know (and why).
-Bowden system? what is the best way to minimize the problems that follow with it? Should I start with the extrude'r on top and evolve to a bowden later?
-The wheels on the bed plate are symbols. I haven't decided on what to use yet. I was maybe thinking putting "skates" on the 4 sides for a even, solid slide. I want to keep the bed as light and slick as possible, so that the pulley/cable dose not struggle. but since i am going with the gravity and not against it, I am not that worried.
- I am already rethinking the way I will cut and make the structure.
Re: Building Core XY Printer: need help deciding on what built March 24, 2015 09:36AM |
AndrewBCN
LarsK
Extruder mechanism: I think that on the CoreXY it really does not matter that much. If you position the motor on the carriage or use Bowden. But use direct extruder for simplicity. Again - Much easier just to buy that bigger Nema...
Well, it matters, because you want to minimize the mass of the moving head, to achieve the maximum potential speed of the CoreXY mechanism. That's why most CoreXY printers use a Bowden system. Unfortunately, using a Bowden system also brings its share of problems and further design decisions and compromises... So it's not that simple. Decisions, decisions...
Re: Building Core XY Printer: need help deciding on what built March 24, 2015 10:07AM |
J.A.C.
Re: Building Core XY Printer: need help deciding on what built March 24, 2015 01:13PM |
LarsK
AndrewBCN
LarsK
Do you know that because you experimented with it or do you say it because you read it elsewhere? Obviously mass matters in some way. But is it in anyway significant when talking about speeds that the Arduino environment and extruder systems can handle?
LarsK
Maybe you could try to do two prints, one normal at max speed and then the same but with 0.5 kg bootstrapped to carriage and see how much it matters?
LarsK
Personally I think the far biggest advantage of the CoreXY system to the cartesian system (like the one JAC presented) is that you have two motors working together to do a motion. If we assume there is a small error in motor one and it stops 1 later then motor two then the error the extruder will see is the average of the two. Thus 0.5. That fact, that errors and misalignment in the two systems of motion averages out is why it is good.
Re: Building Core XY Printer: need help deciding on what built March 24, 2015 02:57PM |
AndrewBCN
Unfortunately your math is wrong... think about it for a moment...
Include an error factor in these equations and you'll notice that any error in A or B will cause an error of half magnitude in both X and Y i.e. the total error remains exactly the same, it is not halved as you incorrectly concluded above. Also, you should be aware that random errors in any system do not cancel out, they add up, just like noise.
Re: Building Core XY Printer: need help deciding on what built March 25, 2015 12:15AM |
Re: Building Core XY Printer: need help deciding on what built March 26, 2015 03:14AM |
Re: Building Core XY Printer: need help deciding on what built March 26, 2015 08:17AM |
Re: Building Core XY Printer: need help deciding on what built March 26, 2015 04:12PM |
Re: Building Core XY Printer: need help deciding on what built March 26, 2015 04:50PM |
Re: Building Core XY Printer: need help deciding on what built March 26, 2015 05:43PM |
Re: Building Core XY Printer: need help deciding on what built March 26, 2015 09:06PM |
Re: Building Core XY Printer: need help deciding on what built March 26, 2015 09:14PM |
