Re: New printer build! My CoreXY. May 21, 2016 08:33PM |
robkar
Wow lkcl, what a response! Where to start?
These are good points, I understand that my bed is levered around my X-axis. I have been considering a three point Z-axis before, I have this hidden in my CAD assembly:
This exact belt path will not work though, one of the screws will rotate the wrong direction
But it can be solved by putting an idler or two close to the motor / back screw, so that it rotates in the same direction as the others.
The orange rods are 8mm lead screws, the grey ones are 12mm smooth rods. The belt here is actually 1750 mm long.. Will the elasticity (assuming standard China-made GT2 belt) cause any problems? Like in syncing the screws?
Based on my initial tests of my current setup the bearings make it pretty solid anyhow, so I will probably do some test prints before modifying it (I only have two lead screws at hands atm, need to order and wait for one more to arrive to test the three point concept.. ) One should also remember, many printers do just fine with completely cantilevered beds, bearings exist for a reason
lkcl
the original design that you had was much much better for structural integrity.
This is also mostly true. But I will not remove the front top bar completely, just move it down in order for the bed to be very accessible. I did also write that if it is not rigid enough, it is SUPER easy to move back to the top position.
Since you built a foldable printer I am pretty sure you can understand that there are reasons for not building the optimal machine from a structural mechanics point of view. My reason is that I want something that looks cool, is easy to work with and a little bit different. Yours was that you wanted it to be foldable!
Re: New printer build! My CoreXY. May 21, 2016 08:38PM |
robkar
Hehe yes. To be honest, most of the stuff I print is actually new parts for my 3D printer! This is the fun part, testing new stuff etc.
Re: New printer build! My CoreXY. May 22, 2016 06:00AM |
Re: New printer build! My CoreXY. May 22, 2016 11:42AM |
Re: New printer build! My CoreXY. May 22, 2016 01:03PM |
Re: New printer build! My CoreXY. May 22, 2016 03:21PM |
lkcl
robkar
ehn? how the heck did you manage to do that?!
Look at the CAD screenshot of the (pretty stupid) Z-axis concept. Imagine the motor rotates clockwise, follow the belt and look at how the three screws will rotate.
mmmm rumble, grumble mumble - look up what the_digital_dentist did. and see the discussion arouuund... mmm... page 6 to 7 of the Fusebox forum. yeahh it _can_ be done, there are printers that have done it... then you do the "digital_dentist" test which is to try to pull a part off a heated printbed hard, whilst it's still cooling down, and you can *see* how much the bed goes "bend, bend, flex"... and you go... "ah. damn"
Of course a cantilevered bed will flex if you pull/hit/bend it. The thing is, you will not do that while printing. Sure, some dynamic effects can be transferred from moving the printhead, but for smaller beds it sure works.
see the double-level of extrusion all the way round? like that, only both layers level, and with corner-brackets on the inside on both levels, too. that would do the trick. i did see one where someone filled both levels with plywood - even hardboard would do the trick, you want to stop the rhombussing-effect of both bottom levels. hardboard's a low-cost way to do it.
I understand what you mean, I know my latest design will be less structurally rigid. However, I will test if it really affects print quality.. I have now put it together (tapping all holes and aligning everything once again was freakin boring!!) and it really is not very flexible when I am pulling the front cornes apart. I will also put panels on its sides and the lower front part. Would it be more rigid if I put the front bar at the top? Of course. Do I like the open design of it as is now? Yes.
The new belt path seems to work fine!
Re: New printer build! My CoreXY. May 22, 2016 06:44PM |
robkar
Re: New printer build! My CoreXY. May 23, 2016 01:13PM |
Re: New printer build! My CoreXY. May 23, 2016 01:48PM |
Re: New printer build! My CoreXY. May 23, 2016 04:39PM |
FA-MAS
Perfect, what you've built is exactly what I have in the drawings for my machine, as far as the CoreXY part goes (mostly), I actually had a question about the linear rail for the X, as the carriage gets towards the middle, does the weight flex it down at all?
Looks like you've got a supporting piece of metal that the X rail connects to, and that connects to the Y linear blocks. In the scenario that say one of the linear blocks moved slightly while one remained stationary, would you expect that metal and rail assembly to flex at all?
Re: New printer build! My CoreXY. May 23, 2016 04:58PM |
the_digital_dentist
You've given up a lot of rigidity in the frame by eliminating the top front frame member. I would put it back in there and add a Zmax switch, then use the custom gcode in slic3r to send the bed to Zmax when a print is finished. It will leave the bed at the bottom of the machine where you can easily remove the print and will leave the extruder wide open for cleaning, etc. The frame member at top front will also make the printer easier to enclose, should the urge strike you. It is also a convenient place to mount lamps to illuminate the print.
Re: New printer build! My CoreXY. May 23, 2016 05:38PM |
Re: New printer build! My CoreXY. May 23, 2016 05:40PM |
robkar
As I said before, I am aware of that. Both the rigidity part, and the enclosure aspect. As I also wrote before, it is extremely easy to mount the bar there IF I later on would like to, I have one spare that is already tapped and prepared. Just to prove my point I made a video for you guys:
link to video
Re: New printer build! My CoreXY. May 24, 2016 01:23PM |
asbo
The stuff Mutley sells is called PrintBite and works better than PEI.Quote
lkcl
is that from mutley3d.com?
Re: New printer build! My CoreXY. May 27, 2016 09:16AM |
My PrintBite isn't black, it's a sort of yellow beige colour, not that it matters since dc42s IR sensor works perfectly on itQuote
robkar
asbo
lkcl
I had planned to buy a PEI sheet for the bed, but now I actually bought a piece of this Printbite instead. I hope it is good! Since I am using dc42s ir sensor it is also convienient that the Printbite is black and do not need any painting, unlike PEI. In terms of price the difference was not that big either, at least not for a rectangular sheet. PEI is probably cheaper, but I couldn't find any good prices for shipping it to Sweden..
Re: New printer build! My CoreXY. May 27, 2016 05:14PM |
asbo
robkar
asbo
lkcl
So far everything I've tried on the PrintBite just works, but I know Mutley gives really good customer support if you have any problems.
Re: New printer build! My CoreXY. May 27, 2016 05:45PM |
Re: New printer build! My CoreXY. July 19, 2017 10:45PM |
