How to set up belt tension
April 20, 2016 12:15PM
I am way on my way to completing my D-Bot variant and have just threaded the GT2 belts, attached one end of each to the X carriage and was about to attach the other ends when it dawned on me that I didn't have a clue how tight they should be and indeed how to adjust the belts after some use?
appjaws - Core XYUV Duet Ethernet Duex5
firmware 3.1.1 Web Interface 3.1.1
Ormerod 1-converted to laser engraver, Duet wifi
OpenSCAD version 2020.07
slic3r-1.3.0, Simplify3D 4.1.2, Cura-4.4.1
Re: How to set up belt tension
April 20, 2016 01:23PM
They should be tight enough to not have slop when moving back and forth.
They should not be so tight they rip your carriage in half.
April 21, 2016 01:14PM
By industry guides:
I would not use longest or shortest span.
Lock down carrige(s) while tensioning
confused smiley
Anonymous User
April 26, 2016 02:00PM
cozmicray
By industry guides:
[attachment 76834 Belt_deflection.jpg]
[attachment 76835 Belt_force.jpg]
confused smiley
Very strange numbers. You know we are in the 21° century smiling smiley
Just use a portable small scale with a hook.
You attach it to an unfastened idler pulley and pull till you read the tension value then fasten it. If the two belts strand are //, a value of 26N is fine (13N per strand is good for a 6mm wide GT2). If not //, just pull in the direction that bisects the angle formed by the strands. The force you will have to reach is 26N x cosine (angle/2).
It is accurate enough.
In our case, it is more convenient than to use the deflection method and better with long belts.
Edited 4 time(s). Last edit at 04/27/2016 12:20AM by MKSA.
