My coreXY design is progressing to the build stage May 04, 2016 01:12AM |
Re: My coreXY design is progressing to the build stage May 04, 2016 02:28PM |
Re: My coreXY design is progressing to the build stage May 04, 2016 03:08PM |
Re: My coreXY design is progressing to the build stage May 04, 2016 11:05PM |
Re: My coreXY design is progressing to the build stage May 05, 2016 03:09AM |
the_digital_dentist
I have just about finished the XY stage design and will be building it shortly. I'll be using 22 mm diameter F608ZZ bearings for the idlers, and designed a self-locking belt clamp for the extruder carriage.
The belt clamp has to keep the belt(s) parallel to the X axis throughout the range of motion, so I laid out the clamp to do just that. The small holes in the top indicate the where the smooth side of the belt enters the clamp. There will be two of these clamps stacked on top of each other, one for each belt.
Re: My coreXY design is progressing to the build stage May 05, 2016 08:29AM |
Re: My coreXY design is progressing to the build stage May 05, 2016 12:36PM |
cozmicray
Printed parts - the green brackets ?
I thought that was a no-no (all metal)
Guide rails are not going to be mounted to any support?
What CAD SW do you use?
Re: My coreXY design is progressing to the build stage May 05, 2016 12:43PM |
lkcl
niiice. i like how they clamp together so no need for tensioning etc. etc. oo, it's got me thinking. how about putting (either a real or) a GT2 gear in the centre and wrapping the belt around it then clamping that down? you could then change the tension on an resolution greater than a single belt-tooth. alsooo... not using a GT2 but just a circular spinning bit of plastic... you miiight be able to put the two belts back-to-back in double spirals (so they lock one against the other) and then similarly tension them up.
the arrangement would be pretty much exactly like one of those retractable laptop mice USB cables:
[attachment 77566 images.jpeg]
wouldn't need bearings...
but... thinking about it, i do like the simplicity of what you came up with...
Re: My coreXY design is progressing to the build stage May 05, 2016 12:44PM |
realthor
Will you be using the same guides for Z? If not then what will you use?
Re: My coreXY design is progressing to the build stage May 05, 2016 01:07PM |
Re: My coreXY design is progressing to the build stage May 05, 2016 01:59PM |
Re: My coreXY design is progressing to the build stage May 07, 2016 07:25PM |
the_digital_dentist
In the scheme you're talking about, you need some sort of ratchet mechanism (or very strong spring) to maintain the tension.
I considered some sort of sliding mechanism where you tension the belts with screws, but again, it gets too big and complex without offering any real benefit. O course, maybe I just haven't figured out the right way to do it...
no don't tell me - all the ways i can think of are horribly fiddly.|
Re: My coreXY design is progressing to the build stage May 07, 2016 08:46PM |
Anonymous User
Re: My coreXY design is progressing to the build stage May 08, 2016 12:53AM |
the_digital_dentist
Thanks, but I can't quite match your description to the picture.
I think I'll be able to design and fabricate a motor mount that will work. The tension on the belt doesn't need to be like a guitar sting- you can easily pull it tight enough with one hand and tighten screws with the other. If that isn't enough tension for some reason, a screw that pulls on the motor will certainly do the job.
Re: My coreXY design is progressing to the build stage May 08, 2016 12:51PM |
the_digital_dentist
Re: My coreXY design is progressing to the build stage May 08, 2016 02:17PM |
Re: My coreXY design is progressing to the build stage May 08, 2016 02:27PM |
Re: My coreXY design is progressing to the build stage May 08, 2016 04:55PM |
cozmicray
ikcl
by the state of your phillips bolt head
time for a proper phillips screw driver
or use hex (allen) head bolt
oh --- I know kitchen utensils used
your Timing belt jam --- kluge at best
why not
[attachment 77731 Belt_jam.jpg]
Re: My coreXY design is progressing to the build stage May 08, 2016 05:06PM |
the_digital_dentist
Ikcl,
Hmmm. You have to manually position the belt to use this clamp to also tension the belt.
- then pop the belt out, keep your fingers on it so you know where it was, move it up by one (or two) notches... tighten the screw back up... not too much. doesn't have to be completely locked down to at least hold the belt in place, it's rubber, it compresses, so even just loose on the screw the belt still stays inQuote
That's a tricky thing to do.
This is the belt clamp on my current printer: Belt Clamp which is a smaller version of the thing I designed for the coreXY. I suppose I could manually pull at the belt and tension it using the clamp the same way your clamp does, except that I don't need any tools to do it. It might be pretty hard to achieve reasonable tension that way.
I am thinking I'll make the motor mount in two pieces that fit together, a fixed piece screwed to the base plate, and a sliding piece that screws to the motor. The two pieces will fit together with tongues and grooves that will constrain the motor's motion to sliding and not tilting.
Re: My coreXY design is progressing to the build stage May 08, 2016 05:27PM |
Anonymous User
Re: My coreXY design is progressing to the build stage May 08, 2016 07:32PM |
Anonymous User
Re: My coreXY design is progressing to the build stage May 08, 2016 07:37PM |
cozmicray
ikcl
Or maybe a Japanese JIS ?|
Re: My coreXY design is progressing to the build stage May 08, 2016 11:29PM |
the_digital_dentist
Re: My coreXY design is progressing to the build stage May 09, 2016 04:50AM |
Re: My coreXY design is progressing to the build stage May 09, 2016 07:35AM |
Re: My coreXY design is progressing to the build stage May 09, 2016 01:22PM |
Re: My coreXY design is progressing to the build stage May 09, 2016 06:34PM |
Re: My coreXY design is progressing to the build stage May 09, 2016 09:02PM |
Re: My coreXY design is progressing to the build stage May 10, 2016 02:38AM |
Re: My coreXY design is progressing to the build stage May 10, 2016 12:12PM |
