Re: CoreXYNZ build February 09, 2017 10:41PM |
SatorCodex
Hi!
Ive been reading thru this thread.
Very nice build and skills from you!
I got alot of input from it. For my own coming build.
Don't be afraid to make more posts here!![]()
Pictures and videoclips.![]()
May I ask how much is warps when you heat it up? (if you have measured it when heated?)
I like the duetwifi board. That probe looks very promising.
Re: CoreXYNZ build February 09, 2017 10:57PM |
Re: CoreXYNZ build February 10, 2017 08:59AM |
Re: CoreXYNZ build February 10, 2017 04:06PM |
I will weigh it today. It is a one person lift although a bit awkward so I am going to put lift handles on it.Quote
the_digital_dentist
Any idea how much it weighs? How are you sending files to it to print?
Re: CoreXYNZ build February 10, 2017 05:26PM |
Re: CoreXYNZ build February 11, 2017 10:02PM |
Re: CoreXYNZ build February 12, 2017 03:59AM |
Re: CoreXYNZ build February 12, 2017 11:11PM |
Re: CoreXYNZ build February 13, 2017 12:04AM |
Re: CoreXYNZ build February 13, 2017 01:50PM |
Yes that would be nice. I haven't seen any setups for a dedicated enclosure heater so I have made no provision for one. At this stage I was hoping the bed heater would do the trick. I have some colour controllable LED strip which I would like to use as temperature indicator and lighting. An air circulating fan seems like a good idea too. I do have an enclosure (wardrobe) heater that has a fixed cutoff at 65degrees C which is for curing my composite projects but it is way too clunky.Quote
the_digital_dentist
Noice!
Will you be adding an enclosure heater?
Re: CoreXYNZ build February 13, 2017 05:12PM |
Re: CoreXYNZ build February 13, 2017 07:12PM |
Re: CoreXYNZ build February 13, 2017 08:52PM |
Re: CoreXYNZ build February 13, 2017 11:35PM |
Re: CoreXYNZ build February 20, 2017 03:48PM |
Re: CoreXYNZ build March 09, 2017 12:44PM |
Re: CoreXYNZ build March 10, 2017 01:56PM |
Kewtdz
Very impressive build. How are you liking the PrintBite surface? It seems to be working well on that ABS Polycarbonate, did you have to do any prep?
Re: CoreXYNZ build March 11, 2017 02:45PM |
Re: CoreXYNZ build March 12, 2017 01:31AM |
Re: CoreXYNZ build March 12, 2017 03:43AM |
o_lampe
Regarding the WiFi issue: Aren't there modules that allow remote antennas?
Re: CoreXYNZ build March 12, 2017 06:16AM |
Re: CoreXYNZ build March 12, 2017 06:28AM |
RodF
I really like the WiFi interface, but at work it is an issue with range and security (dealing with the IT dept.) So I am interested to see how the PanelDue works out.
Re: CoreXYNZ build April 16, 2017 05:30PM |
. I had some difficulty printing the large enclosure for it in ABS with the .8mm volcano nozzle. Thanks to Azerate over on Soliforum for slicer settings I ended up with a good result.|
Re: CoreXYNZ build February 10, 2018 06:19PM |
Re: CoreXYNZ build January 29, 2019 06:56AM |
Re: CoreXYNZ build January 30, 2019 06:14AM |
