Overengineered CoreXY January 27, 2017 03:34AM |
Re: Overengineered CoreXY January 27, 2017 04:49AM |
Re: Overengineered CoreXY January 27, 2017 04:56AM |
Re: Overengineered CoreXY January 27, 2017 07:56AM |
Re: Overengineered CoreXY January 27, 2017 09:12AM |
Re: Overengineered CoreXY January 27, 2017 12:29PM |
Re: Overengineered CoreXY January 27, 2017 12:48PM |
Re: Overengineered CoreXY January 27, 2017 01:19PM |
to responde to this let me ask other question:Quote
cozmicray
Does a PLA cooler fan really work -- or prevent layer to layer adhesion?
E3D v6 little: it was a ptfe tube that goes from the extruder diretly to the nozzle, very dificult to get a jam.Quote
cozmicray
A good hotend that doesn't jam ----- Holy Grail of FFF printing
if possible without lossing print quality them YES. This is common sense...Quote
cozmicray
Do you really need print to be completed in 26 sec ? 50m/sec filament feed rate 100m/sec XY speeds.
where is the fun of this? this forum is about building printer and not selling them..Quote
cozmicray
you want a rock solid printer --- save up your money buy a 3D systems projet series printer
what wrong with the list I have done?Quote
cozmicray
One has to assess what effects print quality
and
Knock off the items on the list to get at quality prints
Never have seen a list of what drives quality printing.
Re: Overengineered CoreXY January 27, 2017 02:15PM |
Re: Overengineered CoreXY January 27, 2017 02:19PM |
filipeCampos
Having a bad day? from your last post and if your are a amercian i pretty sure you voted trump..
Re: Overengineered CoreXY January 27, 2017 04:32PM |
Re: Overengineered CoreXY January 27, 2017 04:57PM |
Re: Overengineered CoreXY January 27, 2017 05:03PM |
Re: Overengineered CoreXY January 27, 2017 07:45PM |
I'll have to think about this one. I doubt their mill will have enough volume to machine after welding.Quote
the_digital_dentist
I'd talk to the people at the makerspace about what you're doing before you weld the frame together. Milling machines have limited addressable volume and your printer frame might exceed the limits if you weld it together before milling.
OTOH, if you mill it before you weld it you're right back to the alignment problem you wanted to fix by milling the frame.
This sort of stuff is where the fun lies in building 3D printers. You not only have to design it, but you also have to figure out how to build it.
Re: Overengineered CoreXY January 27, 2017 07:51PM |
Thanks for the suggestion. So you're saying don't mount the coreXY mechanism to the frame, but use some kind of bracket system hanging inside the frame?Quote
prot0typ1cal
anvoice,
Regarding your frame, if you make the corner spars taller, you can still mount your CoreXY stuff inside the 90 via adjustable brackets so machining is not required, and keeps your top flat for the enclosure.
If tall enough, the filament spool will also be inside, no escape for the warm air. I think DD said he is doing this for his Trump tower. Sry DD, no offense intended.
The extra cost/weight of the angle is far less than the added benefits.
Suggest you invert the angle iron for the bottom sides. This allows for a flat shelf that is easily cleaned, and provide a protected, open bottom for your electronics.
The coefficient for thermal expansion for steel is about half that of aluminum, neighborhood of .0006"/100 F/inch. F'yea, I'm Murican. So try to match your enclosure panels to be about the same.
Since you're going for an enclosure, maybe use perforated 90 degree steel (stuff used for racks and shelves). Lightens the whole weight and provides easy mounting.
Consider painting the steel, ounce of prevention, unless it's gonna be stainless :p
Re: Overengineered CoreXY January 27, 2017 08:59PM |
filipeCampos
cozmicray
can you tell me a good pla printer that does not have one or more cooling pla fan?
If is planning to build a printer for pla is need to plan the space for one or more fans.
cozmicray
cozmicray
cozmicray
cozmicray
and
Re: Overengineered CoreXY January 28, 2017 03:13AM |
Re: Overengineered CoreXY January 28, 2017 07:24AM |
Re: Overengineered CoreXY January 28, 2017 08:42AM |
Re: Overengineered CoreXY January 28, 2017 12:34PM |
Re: Overengineered CoreXY January 28, 2017 02:51PM |
What would you suggest for a way to align the coreXY subframe? Aluminum extrusion? Or not supporting as cozmicray suggests?Quote
the_digital_dentist
It doesn't sound like a reliable way to ensure that all the guide rails are aligned. I think that making the main frame as a fixture to hold an XY subframe and a Z subframe is going to be more reliable because it allows adjustment of the relative positions and angles between the subframes. Drilling holes or even milling slots for screws in the main frame members is a lot easier than welding, testing, breaking welds and rewelding and testing again, etc.
Re: Overengineered CoreXY January 28, 2017 03:40PM |
Re: Overengineered CoreXY January 28, 2017 03:43PM |
Re: Overengineered CoreXY January 28, 2017 04:16PM |
Re: Overengineered CoreXY January 28, 2017 04:24PM |
Re: Overengineered CoreXY January 28, 2017 04:43PM |
Re: Overengineered CoreXY January 28, 2017 06:59PM |
Re: Overengineered CoreXY January 29, 2017 04:34AM |
Re: Overengineered CoreXY January 29, 2017 06:18AM |
Re: Overengineered CoreXY January 29, 2017 09:34AM |
