Re: My CoreXYU Printer project July 18, 2017 07:47AM |
Re: My CoreXYU Printer project July 18, 2017 10:01AM |
Re: My CoreXYU Printer project July 19, 2017 02:59AM |
Re: My CoreXYU Printer project July 19, 2017 04:22AM |
What do you mean with "easiest"? Do you have a link for such a pump?Quote
o_lampe
The easiest diaphragm pump I've seen has a mains voltage solenoid instead of a motor. Not sure about the noise level, but it has no brushes and the hinge doesn't see any sideload, like the bearings of a motor would. And there are less moving parts, so there's less chance to create extra noise over time.
Re: My CoreXYU Printer project July 19, 2017 02:56PM |
Re: My CoreXYU Printer project July 19, 2017 03:50PM |
Re: My CoreXYU Printer project July 19, 2017 09:26PM |
Re: My CoreXYU Printer project July 20, 2017 01:31AM |
dc42
The other way to prevent ooze is to use set the standby temperature lower than the active temperature and retract a significant amount of filament when a hot end goes to standby. This works extremely well on my dual-nozzle Ormerod, using a standby temperature of 150C and 10mm retraction (less retraction might work but I haven't tried). However, all-metal hot ends don't take kindly to large amounts of retraction, so you would probably need to use en E3D Lite 6 with this technique rather than the E3DV6.
Re: My CoreXYU Printer project July 20, 2017 03:01AM |
newbob
I wonder how much output would be sufficient? Ultimaker (for example) has two fans 9L/min (2.2cfm) each - therefore I suppose 1/4 of that output should be sufficient when using air nozzle which would be 4.5-9L pump. Probably would be good to get 15L and turn it down with a valve.
I don't think DC pump could be regulated with PWM like DC motor pumps can be (maybe it would be possible to plug in solenoid directly to PWM signal?).
Since not much pressure is needed, and variable cooling rate is nice to have, maybe few fans in series would be a better solution.
newbob
Only 1.3L / min. I don't know what it should be but it seems rather low.
Re: My CoreXYU Printer project July 20, 2017 03:26AM |
lkcl
dc42
dc42, lars: have you investigated the mutley3d dual-filament hot-ends at all? two filaments come in, mix *inside* the hot-end, filaments comes out of a *single nozzle*. you can therefore do *blending* of two colours. yes i believe jason may actually be considering a triple so that it's possible to do virtually any kind of colour-mix you desire. awesome stuff as it saves a considerable amount of space. also all the problems with "active" and "standby" temperatures, and associated delays in changeovers - all those problems go away. selecting which filament you want is give-or-take immediate (small latency due to there being a small amount of the previous filament still in the hot-end).
p.s. lars your design looks really good. love the bright red. brace those open faces (all six) and you'll be able to increase the speed without getting artefacts from frame-shaking. [reprap.org]
Re: My CoreXYU Printer project July 20, 2017 04:07AM |
lkcl
dc42
Re: My CoreXYU Printer project July 21, 2017 03:50AM |
Re: My CoreXYU Printer project July 21, 2017 12:49PM |
Once you have managed to bend the pipe and positioned it a normal pipe works. I guess a gooseneck pipe would be easier to bend and position but it would be a bit bulkier. I might be knocked out of position easier...?Quote
o_lampe
I wonder if gooseneck pipe is any good for air cooling with a pump? You could aim it anywhere you want.
Re: My CoreXYU Printer project July 30, 2017 04:32PM |
Re: My CoreXYU Printer project August 01, 2017 06:47PM |
That motor has phosphor bronze brushes like a cheap toy. It isn't designed to operate for more than a few hours because the brushes wear out and can't be replaced. I'd also be surprised if it can operate for more than a few minutes at "rated voltage" without burning itself up. OTOH, maybe the bronze bushings will wear out before the brushes.
Re: My CoreXYU Printer project August 02, 2017 02:13AM |
Qdeathstar
The berdAir uses that same motor and I've had no problem running it for 24hrs at a time... I've probably put overly 200 hrs on it and the thing still chooches. It is LOUD though. I did put heat sink and fan on it though cause it was getting hot....
Re: My CoreXYU Printer project August 02, 2017 11:10PM |
Re: My CoreXYU Printer project August 03, 2017 03:07AM |
I would not have thought that would be effective! Good to know. I have been looking at possibly getting a RC motor heatsink. Somehing like this or this. They should fit on a 36mm diameter motor. Will have to check if the metal piece attached to the motor that I guess is a heatsink can be removed (the one with the model text on it).Quote
Qdeathstar
It's surprising how well it works despite the small contact surface area. The motor was hot to the touch without the heat sink and fan, with it it is barely warm.
Re: My CoreXYU Printer project August 03, 2017 07:39AM |
Re: My CoreXYU Printer project August 03, 2017 07:09PM |
Re: My CoreXYU Printer project August 04, 2017 02:36AM |
Re: My CoreXYU Printer project August 04, 2017 03:15AM |
o_lampe
This extra metal shield wrapped around the motor housing is there to increase torque. It improves the magnetic field path between the two magnets inside.
Removing it will make the motor spin faster at same voltage, but it'll be a bit weaker too.
Re: My CoreXYU Printer project August 05, 2017 03:19AM |
Re: My CoreXYU Printer project August 05, 2017 03:27PM |
Re: My CoreXYU Printer project August 08, 2017 02:47PM |
Re: My CoreXYU Printer project August 09, 2017 03:27AM |
Re: My CoreXYU Printer project August 09, 2017 05:15AM |
o_lampe
Would be interesting to see the circuit.
I doubt you will change much with PWM control. The duty cycle would have to be 50:50 and a lower frequency could overheat the coil. The best you can try is to lower the input voltage ( fast PWM with a large capacitor in parallel ) and keep the circuit as is.
Bad news is, there are two valves inside the bellows, which might need some "bang-bang" to open/close effectively.
Re: My CoreXYU Printer project August 10, 2017 04:22AM |
Re: My CoreXYU Printer project August 10, 2017 04:47AM |
Re: My CoreXYU Printer project August 11, 2017 01:50AM |
