Zasquatch's CoreXY Design/Build August 15, 2017 10:22AM |
Re: Zasquatch's CoreXY Design/Build August 15, 2017 10:28AM |
Re: Zasquatch's CoreXY Design/Build August 15, 2017 10:40AM |
Re: Zasquatch's CoreXY Design/Build August 15, 2017 10:42AM |
Re: Zasquatch's CoreXY Design/Build August 21, 2017 01:36PM |
Re: Zasquatch's CoreXY Design/Build August 21, 2017 02:04PM |
Re: Zasquatch's CoreXY Design/Build August 21, 2017 02:28PM |
Re: Zasquatch's CoreXY Design/Build August 21, 2017 03:59PM |
Re: Zasquatch's CoreXY Design/Build August 21, 2017 04:41PM |
Re: Zasquatch's CoreXY Design/Build August 22, 2017 02:33PM |
Zasquatch
2" x 5" x .125" thk
Not sure if my nozzle leveling idea is the best, if there are suggestions I'd like to hear them. Right now just planning to machine ovals for the stepper and mounting holes... loosen the whole titan, drop to a spacer on the bed, and tighten. Repeat for second extruder. Simple but not sure how it will work practically.
Re: Zasquatch's CoreXY Design/Build August 22, 2017 03:33PM |
Origamib
Zasquatch
2" x 5" x .125" thk
One of the screws for the motor on the titan is actually behind the hotend, so it would be unpractial to use it for levelling.
My preferred method would be an e3d Kraken heat break that is secured with a set screw (non threaded [e3d-online.com]). Could be quite easily made just by drilling a heatsink, or perhaps ask e3d for a non threaded heatsink? China does quite a few variations of heatsinks so may be possible to use one of those
Re: Zasquatch's CoreXY Design/Build August 24, 2017 05:40AM |
Zasquatch
It may not be that easy, these are the titan aeros, which have the heat sink built into the extruder.
I will reach out to e3d for ideas, hadn't thought of that!!
Origamib
Zasquatch
2" x 5" x .125" thk
Re: Zasquatch's CoreXY Design/Build August 24, 2017 05:50AM |
Re: Zasquatch's CoreXY Design/Build August 24, 2017 04:50PM |
Re: Zasquatch's CoreXY Design/Build August 24, 2017 04:52PM |
Re: Zasquatch's CoreXY Design/Build August 24, 2017 07:53PM |
Re: Zasquatch's CoreXY Design/Build August 24, 2017 08:10PM |
Re: Zasquatch's CoreXY Design/Build August 24, 2017 09:36PM |
Re: Zasquatch's CoreXY Design/Build August 25, 2017 03:01PM |
Re: Zasquatch's CoreXY Design/Build August 25, 2017 03:18PM |
Re: Zasquatch's CoreXY Design/Build August 26, 2017 08:54AM |
Re: Zasquatch's CoreXY Design/Build August 27, 2017 03:22AM |
Re: Zasquatch's CoreXY Design/Build August 27, 2017 06:40AM |
Re: Zasquatch's CoreXY Design/Build August 27, 2017 09:45AM |
Re: Zasquatch's CoreXY Design/Build August 27, 2017 09:56AM |
Re: Zasquatch's CoreXY Design/Build August 27, 2017 10:14AM |
Re: Zasquatch's CoreXY Design/Build August 27, 2017 10:35AM |
Re: Zasquatch's CoreXY Design/Build August 27, 2017 10:43AM |
Re: Zasquatch's CoreXY Design/Build August 27, 2017 11:19AM |
Re: Zasquatch's CoreXY Design/Build August 27, 2017 11:36AM |
