Corners on round shapes July 15, 2018 08:00AM |
Re: Corners on round shapes July 15, 2018 08:57AM |
Re: Corners on round shapes July 15, 2018 09:27AM |
What acceleration, jerk, speeds, motor currents are you using?
Re: Corners on round shapes July 15, 2018 01:34PM |
Re: Corners on round shapes July 15, 2018 09:18PM |
Re: Corners on round shapes July 16, 2018 12:27AM |
Re: Corners on round shapes July 16, 2018 07:37AM |
-> No I am printing at about 50-60mm/sQuote
Are you printing at high speeds?
-> 8mm Rods for both x(410mm length) and y(425mm length)Quote
What diameter and length are you using for the y rods?
-> Yep Steel core GT2 but with 24teeth pulleys (~12mm Diameter) and fl624zz bearings (13mm Diameter)Quote
I see white belts. Are you using steel core with a too small pulley diameter?
Re: Corners on round shapes July 16, 2018 08:22AM |
Re: Corners on round shapes July 16, 2018 08:50AM |
Re: Corners on round shapes July 16, 2018 03:44PM |
The ones from the bed? No they are fineQuote
boredom.is.me
The lead screws are constrained. Make sure they aren't bent.
Nope as mentioned before I am using the LV8729 nevertheless that might be a point. I will try to snap on the standard polulus again and report back thanks for the hint.Quote
the_digital_dentist
Does the machine use DRV8825 drivers
Re: Corners on round shapes July 18, 2018 03:49AM |
Re: Corners on round shapes July 18, 2018 03:58AM |
Re: Corners on round shapes July 18, 2018 11:54AM |
Re: Corners on round shapes July 18, 2018 04:23PM |
Re: Corners on round shapes July 19, 2018 05:52AM |
