The Janky-XY printer August 22, 2018 11:28AM |
Re: The Janky-XY printer August 22, 2018 11:36AM |
Re: The Janky-XY printer August 23, 2018 01:38AM |
Re: The Janky-XY printer August 23, 2018 02:44AM |
Re: The Janky-XY printer August 23, 2018 06:45AM |
Re: The Janky-XY printer August 23, 2018 05:54PM |
Re: The Janky-XY printer August 23, 2018 09:09PM |
Re: The Janky-XY printer August 24, 2018 12:23AM |
Re: The Janky-XY printer August 24, 2018 01:33AM |
Re: The Janky-XY printer August 24, 2018 09:16AM |
o_lampe
Using the leadscrews as Z-guides too is a bit unusual. The print doesn't show any signs of wobble yet, but maybe after some hours of printing?
Re: The Janky-XY printer August 24, 2018 10:10AM |
Re: The Janky-XY printer August 24, 2018 01:46PM |
Re: The Janky-XY printer August 24, 2018 06:14PM |
Re: The Janky-XY printer August 24, 2018 09:10PM |
gmedlicott
Forgot to ask, what is the build volume for your printer? It looks around 1ft cube?
Re: The Janky-XY printer August 25, 2018 06:50AM |
gmedlicott
Three lead-screws will ensure the bed doesn't wobble in the Z-direction but won't help the X and Y wobble much if your bed / print is heavy.
To limit X and Y bed movement, two uprights are needed. Adding a second 2020 on the opposite side of your current one would work, as long as it is very close to parallel to prevent binding. To also limit binding, you could remove the top bearings from the lead screws, though this is more of an issue if you have a very stiff bed plate, and yours being MDF looks like it will have enough play. My Folger FT5 had that issue.
An example of the above scheme is the Fusion3 F306 which had three lead screws and two lateral support members.
Giles
Re: The Janky-XY printer August 25, 2018 02:05PM |
MKSA
At least they didn't commit the usual mistake of one motor per lead screws.
Re: The Janky-XY printer August 25, 2018 06:03PM |
gmedlicott
MKSA
Agreed 100%. My Folger FT5 was a nightmare to keep the bed level as the 4 turn lead screws would move when powered off. I changed to a single z-belt like Obelisk79 has in his design here; much better. I see the newer gen FT5 has this also.
Re: The Janky-XY printer September 16, 2018 01:25PM |
Re: The Janky-XY printer September 16, 2018 03:33PM |
Re: The Janky-XY printer September 17, 2018 07:36AM |
Re: The Janky-XY printer September 17, 2018 01:02PM |
