another new core xy December 31, 2018 10:58AM |
Re: another new core xy December 31, 2018 01:34PM |
Re: another new core xy December 31, 2018 02:36PM |
FA-MAS
I would stack the x-y belts and run them inside the linear rails so you could do away with those extra idlers. You're also going to want to support the idlers on top and bottom. They're going to want to tilt as you tension the belts.
FA-MAS
If you placed your z idlers differently, you could get rid of having to use a separate belt to couple the Z motor to the leadscrews and you'd simplify how you'd have to tension it all, you could just slide the z motor instead of having to do that as well as the idlers.
Re: another new core xy December 31, 2018 02:47PM |
Re: another new core xy December 31, 2018 03:23PM |
Re: another new core xy December 31, 2018 03:59PM |
Re: another new core xy December 31, 2018 04:41PM |
Re: another new core xy December 31, 2018 07:18PM |
Re: another new core xy January 01, 2019 03:02AM |
Re: another new core xy January 01, 2019 04:48AM |
Re: another new core xy January 01, 2019 03:10PM |
Re: another new core xy January 01, 2019 08:14PM |
Re: another new core xy January 02, 2019 05:33PM |
Re: another new core xy January 03, 2019 03:29PM |
Sorry that’s my lazy cad drawing. There are only 3 linear rods. Each rod has a tr8 lead screw paired with it. The tr8 is only restrained at the bottom (in a floating bearing) so hopefully no binding between each rod and screw. There are 3 pairs positioned the way that they are as 3 adjustable points are required to set a flat plane with out inducing twist. I went this route as I do not want the bed to float on spring mounts. I’m hoping to run the printer pretty fast and do not want any bounce or resonance in the bed. My only concern is that thermal expansion while using the bed heater will cause a problem as the bed is rigidly fixed to the bed rails. Currently working on a way to fix the bed in z but allow some small movement in xyQuote
cozmicray
"linear rails run in pairs are hard enough to keep perfectly parallel and true to each other
adding a third would add another level of complexity which I'm not sure I would have the patience for."
One linear rail would replace your dual rod guide .... so only three rails
2 rods parallel --- parallel to two other 2 rod assemblies ---- I see six vectors going every witch way ---
?? Over - constraint ??? binding ???
The DD UMMD only uses 2 linear rails on Z.
Re: another new core xy January 03, 2019 03:38PM |
Re: another new core xy January 03, 2019 06:12PM |
Re: another new core xy January 03, 2019 07:34PM |
You may want to look into klipper, which my slash price more than in half by using Raspberry pi and 2 boards to expand the number of available stepper drivers for 3 or 4 independent Z motors.Quote
TheHandsomeDog
I’m having a hard time justifying the price of duet and panel without adding the expansion board into the mix. (Although it is a pretty cool solution)
Re: another new core xy January 04, 2019 07:43AM |
Re: another new core xy January 04, 2019 02:44PM |
Re: another new core xy January 04, 2019 03:25PM |
Re: another new core xy January 04, 2019 04:18PM |
Re: another new core xy January 04, 2019 06:25PM |
Re: another new core xy January 04, 2019 08:45PM |
Re: another new core xy January 04, 2019 09:26PM |
I do believe that restart is useful only for printing with cold - not heated bed. If the bed cools down the printing part will get off the bed.Quote
the_digital_dentist
If you want to try to recover from a power failure or to shut down a print at night then restart it the next day, when the bed heats up...
The easy solution may be to home Z to MAX instead of MIN (what Delta printers usually do) this may require a change in restart algorithm.Quote
the_digital_dentist
If the bed doesn't go back to the exact same position it will create a defect in the print
Re: another new core xy January 04, 2019 11:37PM |
Re: another new core xy January 05, 2019 06:31AM |
Re: another new core xy January 05, 2019 10:45PM |
Re: another new core xy January 06, 2019 04:18AM |
cozmicray
All you need here is a calliope and a ring master?
Re: another new core xy January 06, 2019 01:02PM |
Re: another new core xy January 06, 2019 01:55PM |
