Circles not round (flat on 2 sides) CoreXY custrom printer February 20, 2019 02:10PM |
Re: Circles not round (flat on 2 sides) CoreXY custrom printer February 20, 2019 03:01PM |
Re: Circles not round (flat on 2 sides) CoreXY custrom printer February 20, 2019 05:00PM |
Re: Circles not round (flat on 2 sides) CoreXY custrom printer February 21, 2019 12:24AM |
Re: Circles not round (flat on 2 sides) CoreXY custrom printer February 21, 2019 07:41AM |
Re: Circles not round (flat on 2 sides) CoreXY custrom printer February 21, 2019 09:40AM |
Re: Circles not round (flat on 2 sides) CoreXY custrom printer February 21, 2019 09:51AM |
Re: Circles not round (flat on 2 sides) CoreXY custrom printer February 21, 2019 01:07PM |
Re: Circles not round (flat on 2 sides) CoreXY custrom printer February 22, 2019 05:13AM |
Re: Circles not round (flat on 2 sides) CoreXY custrom printer February 22, 2019 09:39AM |
The tension of belts will be the same as they are connected through X carriage, but if one belt is longer than other you will get a skewed structure.Quote
3DMind
I even check the tension of the belt using the precise weight and pressing it to a specific point. It's pretty the same.
This gap between perimeters clearly shows that X is not perpendicular to Y as your diagonal length 1 is longer than 2.Quote
3DMind
As you see, there is a gap in the wall in 45degree and the wall on second 45 degree axis is too tight.
Re: Circles not round (flat on 2 sides) CoreXY custrom printer February 22, 2019 09:57AM |
piper3d
piper3d
You may see the effect of belts tension if you move Y to max or to 0 and apply extra tension by hand to one of the belts - your Y carriages will move along Y in opposite directions.
Re: Circles not round (flat on 2 sides) CoreXY custrom printer February 22, 2019 11:20AM |
piper3d
Re: Circles not round (flat on 2 sides) CoreXY custrom printer February 22, 2019 11:25AM |
Re: Circles not round (flat on 2 sides) CoreXY custrom printer February 22, 2019 12:26PM |
Re: Circles not round (flat on 2 sides) CoreXY custrom printer February 22, 2019 01:58PM |
I was referring to the symmetric systemQuote
the_digital_dentist
If motor B was moved up and segments A and J were longer, it would not affect operation of the mechanism. As long as segments A-H are parallel to the guide rails, and the belts have tension set to keep the X axis square with the Y axis, the mechanism will work fine.
Equal belt length is completely unnecessary.
Re: Circles not round (flat on 2 sides) CoreXY custrom printer March 06, 2019 03:03AM |
Re: Circles not round (flat on 2 sides) CoreXY custrom printer March 10, 2019 05:19PM |
