Z Axis Design Help March 02, 2020 11:51AM |
Re: Z Axis Design Help March 02, 2020 05:08PM |
Re: Z Axis Design Help March 02, 2020 05:15PM |
Re: Z Axis Design Help March 02, 2020 05:20PM |
Re: Z Axis Design Help March 02, 2020 08:06PM |
Re: Z Axis Design Help March 03, 2020 05:08PM |
Re: Z Axis Design Help March 04, 2020 12:20PM |
Re: Z Axis Design Help March 04, 2020 02:42PM |
Re: Z Axis Design Help May 24, 2020 05:03PM |
Re: Z Axis Design Help October 15, 2020 10:28AM |
Re: Z Axis Design Help October 15, 2020 11:42AM |
Re: Z Axis Design Help October 16, 2020 09:01AM |
dustinoff
Geometrically, 3 points define a plane, not 4. There is a basic physical problem with 4 point (4 dimension) leveling on a 3 dimension build plate. Picture this: (Using compass points for placement) points 1(N) is your ref point. Points 2(E), 3(W), and 4(S) are high. To adjust this you must simultaneously lower 2, 3, and 4, OR simultaneously raise 1 and lower 4. If you do not do it simultaneously, you will either cause nothing to happen or bend your build plate into 4 dimensions. With a 3 point leveling system, you are adjusting a 3 dimension object and only one point needs to be adjusted at a time.
On my plate, I have one screw fixed and adjust the other 2 individually. The original plan for my printer (Carl Feniak's build) had 4 adjusters. When I adjusted them with a very rigid build plate, the result was to distort the supporting frame resulting in no movement of the build plate.
Re: Z Axis Design Help July 05, 2021 03:08PM |
Re: Z Axis Design Help July 05, 2021 04:05PM |
Re: Z Axis Design Help July 05, 2021 06:50PM |
Re: Z Axis Design Help July 18, 2021 02:38AM |
Re: Z Axis Design Help July 18, 2021 07:36AM |
Re: Z Axis Design Help July 18, 2021 09:32AM |
Re: Z Axis Design Help July 18, 2021 03:00PM |
