Which Model as Basis for Rebuild March 04, 2020 01:20PM |
Re: Which Model as Basis for Rebuild March 04, 2020 01:49PM |
Re: Which Model as Basis for Rebuild March 04, 2020 04:10PM |
blt3dp
1 isn't a CoreXY. The X axis motor is mounted on the Y gantry, so there's that additional mass there that is going to limit your speed/quality. Can't really tell if 2 or 3 are CoreXY, looks like 2 might be.
Between 2 and 3. Can't really see how 2 is constructed. Though it does appear at least at the top there's no supporting structure. Looks like it's acrylic attached to the vertical extrusions (I don't see any horizontal frame members)
I'd go with 3, but trash those corner braces and attach the extrusions directly together, providing they're cut square enough.
Re: Which Model as Basis for Rebuild March 04, 2020 04:22PM |
Re: Which Model as Basis for Rebuild March 04, 2020 05:59PM |
Re: Which Model as Basis for Rebuild March 04, 2020 07:03PM |
boredom.is.me
Do you understand how a core xy works? If so, none of those models will help you as a guide. You're going to end up designing your own thing.
IF you don't understand how a core xy works, just stop and do some research. The first isn't a core xy. The other two have some 'interesting' design choices.
Re: Which Model as Basis for Rebuild March 04, 2020 07:08PM |
the_digital_dentist
If you're shopping specifically for a corexy machine, be sure to look carefully at how the XY belts are routed. Many hobbyists and even some commercial printer makers get it wrong. If you can't see the belt layout, don't buy/build it!
If you use a screw to lift the Z axis, how do you position the screw? You put it parallel to the Z axis guide rails. Why? because if you don't, it won't work right. When you tell it to move a specific amount, it will move some other amount, until it binds and stops moving altogether.
Belts are similar. They have to be positioned parallel to the guide rails or you won't get the commanded amount of movement - i.e. prints will be distorted.
This diagram shows one way of laying out the belts in a corexy mechanism. There are variations in motor position, number of pulleys, etc., but in any of the variations, segments labeled A-H must be kept parallel to the X and Y guide rails.
In a corexy mechanism, the X and Y axes are kept square by the belt tension. If you don't position segments A-H parallel to the guide rails, the belt tension will vary depending on the position of the extruder carriage in the XY plane. That means the squareness of the axes will vary. That means you will get distorted prints and the nature of the distortion will vary depending on the XY position of the print on the bed. Near the center of the bed distortion is usually smaller, near the corners of the bed it gets worse. If you see clothespin spring belt tensioners (or any other spring loaded tensioner) on a corexy mechanism it is most likely because the belts are not properly positioned in relation to the guide rails. In a properly laid out corexy mechanism, the belt tension doesn't vary as the extruder moves in the XY plane, and the X and Y axes remain square. More info here.
Re: Which Model as Basis for Rebuild March 05, 2020 06:04AM |
Re: Which Model as Basis for Rebuild March 05, 2020 01:18PM |
Re: Which Model as Basis for Rebuild March 05, 2020 05:27PM |
cozmicray
ReBuild?
What is being rebuilt?
What existing parts must you reuse?
What are your NEW requirements?
I have been in search of what factors are important for a good printer?
I am amazed at the performance of the CR-10 I purchased
and just can't figure out what they did right to make a great 3D printer?
Re: Which Model as Basis for Rebuild May 30, 2020 06:11PM |
Doppler9000
I want to improve/replace the parts that are typically below par on Chinese machines.
Probably add a Duet board, maybe Nimble extruder(s), better hot end.
I want a quiet, fast printer that produces great prints with a variety of materials - still debating the full range of materials I want to accommodate.
cozmicray
ReBuild?
Re: Which Model as Basis for Rebuild June 14, 2020 01:01PM |
Re: Which Model as Basis for Rebuild July 01, 2020 11:56AM |
blt3dp
Re: Which Model as Basis for Rebuild July 01, 2020 12:23PM |
Re: Which Model as Basis for Rebuild July 01, 2020 01:23PM |
dustinoff
M3D.11-09
What is the system in model 1, I want to do something like that, but I could not find it. Corexy seems to me inefficient. I can do it in Utimaker, but the system in model 1 makes more sense.
Just curious as to what you think is inefficient about a coreXY.
Re: Which Model as Basis for Rebuild July 01, 2020 02:07PM |
Re: Which Model as Basis for Rebuild July 01, 2020 02:43PM |
