What is the cause of magical random ripples on the Core XY printer? February 01, 2024 09:42AM |
Re: What is the cause of magical random ripples on the Core XY printer? February 01, 2024 01:17PM |
Re: What is the cause of magical random ripples on the Core XY printer? February 01, 2024 02:33PM |
the_digital_dentist
Post some pictures of the prints.
Are the problems only on the Y axis and not on X axis?
Dual drive gear extruders such as the BMG and Sherpa Mini are known to cause uneven Z axis surfaces due to poor meshing of the gears.
Re: What is the cause of magical random ripples on the Core XY printer? February 01, 2024 04:46PM |
Re: What is the cause of magical random ripples on the Core XY printer? February 01, 2024 07:50PM |
Re: What is the cause of magical random ripples on the Core XY printer? February 01, 2024 07:58PM |
Why are you talking about extruder if on X axis all is good?Quote
the_digital_dentist
I don't know if helical gears are supposed to fix the problem associated with dual drive gear extrusion. If you have a single drive gear extruder available, give it a try and see if the problems persist.
What is different when the extruder moves in X and when it moves in Y?
Did you read 1st message? I changed tooth pulleys to bearing and NOTHING CHANGED. NOTHING.Quote
I see stacked bearings at the ends of the X axis with the belt teeth touching the bearing surface. What size are those bearings?
Re: What is the cause of magical random ripples on the Core XY printer? February 03, 2024 10:19AM |
Re: What is the cause of magical random ripples on the Core XY printer? March 19, 2024 07:17AM |
I asked about the diameter of the bearings you are using for pulleys (you gave no answer) because if they are small, they may be the cause of the regularly spaced vertical ripples seen in both X and Y sides of the prints.
There is no opportunity for this in voron design.Quote
That is why I suggested trying a twist in the belt so the smooth side of the belt rides on the bearings
What are the steps/mm values set for each axis? Are they the same (they should be...)?
##################################################################### # X/Y Stepper Settings ##################################################################### ## B Stepper - Left ## Connected to MOTOR_0 ## Endstop connected to DIAG_0 [stepper_x] step_pin: PF13 dir_pin: PF12 enable_pin: !PF14 rotation_distance: 40 microsteps: 32 full_steps_per_rotation:200 #set to 400 for 0.9 degree stepper #endstop_pin: EBBCan: PB5 endstop_pin: tmc2240_stepper_x:virtual_endstop #tmc2209_stepper_x:virtual_endstop homing_retract_dist: 0 position_min: -45 ## UART 2209 # [tmc2209 stepper_x] # uart_pin: PC4 # interpolate: False # run_current: 0.72 # sense_resistor: 0.110 # stealthchop_threshold: 0 #999999 # diag_pin: ^PG6 # driver_SGTHRS: 130 # 255 is most sensitive value, 0 is least sensitive ## SPI 2240 [tmc2240 stepper_x] spi_software_sclk_pin: EXP2_2 spi_software_mosi_pin: EXP2_6 spi_software_miso_pin: EXP2_1 spi_speed: 2500000 cs_pin: PC4 run_current: 0.65 diag0_pin: ^!PG6 #^PG6 driver_SGT: 1 stealthchop_threshold: 0 ## A Stepper - Right ## Connected to MOTOR_1 ## Endstop connected to DIAG_1 [stepper_y] step_pin: PG0 dir_pin: PG1 enable_pin: !PF15 rotation_distance: 40 microsteps: 32 full_steps_per_rotation:200 #set to 400 for 0.9 degree stepper #endstop_pin: PG9 can printhead endstop_pin: tmc2240_stepper_y:virtual_endstop #tmc2209_stepper_y:virtual_endstop homing_retract_dist: 0 position_min: 0 ##-------------------------------------------------------------------- ## UART 2209 # [tmc2209 stepper_y] # uart_pin: PD11 # interpolate: False # run_current: 0.65 # sense_resistor: 0.110 # stealthchop_threshold: 0 #999999 # diag_pin: ^PG9 # use the same pin that was previously the endstop_pin! # driver_SGTHRS: 130 # 255 is most sensitive value, 0 is least sensitive ## SPI 2240 [tmc2240 stepper_y] spi_software_sclk_pin: EXP2_2 spi_software_mosi_pin: EXP2_6 spi_software_miso_pin: EXP2_1 spi_speed: 2500000 cs_pin: PD11 run_current: 0.65 diag0_pin: ^!PG9 #^PG9 driver_SGT: 1 stealthchop_threshold: 0 #999999
Re: What is the cause of magical random ripples on the Core XY printer? March 19, 2024 10:33AM |
Re: What is the cause of magical random ripples on the Core XY printer? March 27, 2024 08:40AM |
