How to check values uploaded to Arduino Board
Posted by Arnold Lane
December 10, 2011 03:54PM
Hi All
I received an Arduino mega 1280 with ramps 1.4 all put together. It has been flashed with sprinter firmware.
I downloaded Arduino software and have connected to the board and tested via the blinking light test
When I try to connect through pronterface it just hangs (I have tried all baud rates)
Could the problem be with the the firmware that has been previously flashed.
Is there a way to check what is on the board and while I am at it check the values for x y z drives etc.
Or am I completly on the wrong track yet again.
Thanks
Re: How to check values uploaded to Arduino Board
December 10, 2011 05:29PM
If you ran the blink test from the Arduino environment you will have erased any firmware previously loaded on the board. You will need to reload it.
December 11, 2011 12:33AM
Thanks nophead
It all makes sense now !
It certainly is an interesting project to embark upon.
It is a case of two steps forward and one back.
Not a learning curve more like a learning wobble.
I'll be back
Arnnie
