Hi All,
I am starting to calibrate my RepRap,but I have a problem where I get some empty spaces at the beginning of each line..
What I noticed is that whenever the wade extruder stops, the pressure from the molten ABS filament forces the stepper to move backwards, so when it restarts extruding, it will take some time until plastic comes out again.
The obvious thing to do for me was to set the "DISABLE_E" to true in the sprinter firmware config.h, but since I am using Gen 7 electronics where all the stepper enable pins are connected, this caused the Z axis to behave strangely where it started skipping layers!! , so I set it back to false where all was back to normal (for the Z at least)
I moved my focus to Skeinforge, where I set the "Restart extra distance" to some values between 1 and 20 mm, and the retraction distance to values between 0 and 10mm, and the minimum travel for retraction to 0, 0.01, 0.1 and 1mm with no difference (I don't remember all the mixes I have used from the above, but I had a lot of attempts)..
Any help or ideas are appreciated..
** Meanwhile, I will move back to the officially supported Teacup firmware and see what happens.. but when I tried it, the heater won't turn on, knowing that when I first tried it, the heater worked
Thanks
