The gcode for extrusion usually specifies the exact number of millimeters to feed into the extruder. If you think it is turning too slowly, you need to look at the number you have in your firmware for z steps/mm. In marlin, this is in the configuration.h file. It's a value that needs to be determined through experimentation. Google "slic3r is nicer" and it will lead you to a nice tutorial for how to calibrate your z steps.
