Hello all,
This is my first reprap and I bought the plastic parts for prusa iteration 2. The problem I'm facing here is that the size of the x axis is bigger than the vertical rods distance.
The distance between the vertical linear bearings of the X end motor and X end idler is 413mm and the distance of the vertical smooth rods is 390mm.
I'm uploading a video showing this problem. it will be available in 10 minutes
http://youtu.be/ABz6w0zBRqg
Te measure of the triangles is 290mm and the horizontal size of the frame is 234mm.
What am I doing wrong here?
Thank you
Ernesto Pareja
dcctrains.netne.net
