This is the story…
Reading the “Triffid Hunter’s calibration Guide” about heated bed and ABS, I found
this link where some guys are talking and experimenting with ABS juice and sugar coating.
I thought that
sugar coating was the best thing to experiment with and after some tests I ended up that was not sufficient because we need something more strong. Anyway the interesting aspect of sugar coating is definitely that: it works. Now, after that experience, I tried something different (with sugar in mind), and finally done some tests with the
almond syrup. It’s easy to understand why: is liquid enough and is sugar saturated.
To compare my resaults with your, I would like to listen about your experiences with almond syrup whenever you will do them. So please, let’s experiment togheter!
I think it’s possible to use any kind of syrup and maybe some “coke” and similar drinks.
But let see…How to use it!
- Clean your plate. I tested the almond syrup on kapton tape and glass. Best resault on glass
- Heat your bed at 80˜90°C
- Mix the almond syrup with really a little quantity of water, just for add a little hydratation
- Using a little brush, put on the plate a thin, very flattened, layer of the mixed almond syrup
- Soon become solid and almost not sticky
- Print with your usual settings for ABS. (ATTENTION: never use cooling fan)
- When the print is over, let cooling down or immerse into water
- Repeat for a new print
And that’s all folks, hope to read about your experiences soon.
Davide Ercolano
P.S.: I posted on
my blog too
