Now, here I might be the wrong guy to talk to... I print slow, I have no other choice because of the type of prints I do, now said that, I designed and printed my own printer, I used the settings I posted above and depending on the part I print anywhere from 20mm per second up to 40mm per second, for an standard prusa parts you can print comfortably at 40 especially if you are printing with ABS, since you need to keep the lower layer warmer to have a good inter layer adhesion.
Your assumption is correct for PLA but not for ABS, if you let the ABS to cool down too much your next layer will not adhere to good to the one below unless you have and enclosed printer with a chamber temperature above 90, then yes, you will have greater results at lower speeds.
Edited 1 time(s). Last edit at 11/14/2014 01:56PM by ggherbaz.
