Please Help ! Uneven layers and i can't find why April 25, 2015 06:40AM |
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 08:24AM |
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 08:34AM |
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 08:43AM |
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 08:54AM |
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 08:58AM |
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 09:02AM |
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 09:10AM |
chris33
your M5 isnt the problem Unless they a captive at the top, they should be able to be free to move it allows it to wobble freely if they slightly not straight, your extruding too much material check the width of extrusion on the thin walled box to see if it matches up with your slicer settings
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 09:26AM |
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 09:41AM |
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 12:34PM |
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 12:41PM |
chris33
because industrial lead/ball screws are engineered to be straight but m5 threaded bar isnt, thats why you see in industrial lead/ball screws can be captive, i should know i work with cncs for my job, and had my i3 for 2 and half years way before all the different variations was out trying to improve it and digital dentist you will never find a straight piece of m5 at all so there will be wobble thats why its not captive ask josef prusa who designed it too he would tell you why its not captive at the top
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 02:52PM |
the_digital_dentist
chris33
What is the logic that leads one from "you'll never find a straight piece of M5 threaded rod" to putting M5 threaded rod into a printer? If the stuff is so awful, don't use it. If it gets bent easily because it's so thin, use a larger diameter rod. If larger stuff is also lousy, use Acme screws.
Given all that, the bearings on the guide rails should determine the motion in the Z axis, not the screws. Or are the bearings are as bad as the screws?
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 04:29PM |
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 05:07PM |
the_digital_dentist
If a little wobble in a 5mm dia screw causes the frame to flex, then the frame is poorly designed/built, too.
Jeez, it's no wonder these things aren't ready for consumer use. Instead of getting more reliable, they're getting cheaper and harder to operate because you have to worry about this sort of nonsense created by stripping out quality in favor of the cheapest way to do things.
I don't think he'll like it but the answer to the OPs question is: You bought a cheesy printer, what did you expect?
Anyway, back to the problem at hand. Your extruder needs to be calibrated and the proper steps/mm needs to be programmed into all axes in order for your printer to provide its best prints. If you have an LCD panel and encoder on your printer you can probably adjust the steps/mm that way, otherwise you'll need to edit the config.h file and recompile the firmware. Read up on calibration here and do what it says: [reprap.org]
After you've got the machine tuned up try a print and see if the problem has gone away.
Re: Please Help ! Uneven layers and i can't find why April 25, 2015 07:15PM |
the_digital_dentist
Re: Please Help ! Uneven layers and i can't find why April 26, 2015 09:25AM |
Re: Please Help ! Uneven layers and i can't find why April 26, 2015 09:30AM |
Re: Please Help ! Uneven layers and i can't find why April 26, 2015 09:47AM |
Re: Please Help ! Uneven layers and i can't find why April 26, 2015 10:00AM |
Re: Please Help ! Uneven layers and i can't find why April 26, 2015 11:34AM |
Re: Please Help ! Uneven layers and i can't find why April 26, 2015 11:47AM |
Re: Please Help ! Uneven layers and i can't find why April 26, 2015 12:03PM |
Re: Please Help ! Uneven layers and i can't find why April 26, 2015 12:36PM |
Re: Please Help ! Uneven layers and i can't find why April 26, 2015 12:40PM |
Re: Please Help ! Uneven layers and i can't find why April 26, 2015 12:53PM |
Re: Please Help ! Uneven layers and i can't find why April 26, 2015 02:14PM |
Re: Please Help ! Uneven layers and i can't find why April 26, 2015 11:57PM |
Re: Please Help ! Uneven layers and i can't find why April 27, 2015 06:24AM |
