Drift
Posted by Jorth2
Drift
July 18, 2012 02:12PM
Im starting to do my first prints and when I print it drifts along the x and y axis equally and constantly. I'm useing the ramps 1.4 board. Any suggestions on how to fix it?
Re: Drift
July 18, 2012 03:21PM
I think I figured out what the problem is. Its skipping steps. Does anyone know how to fix that? Both the x and y axies are skipping steps.
Re: Drift
July 18, 2012 04:21PM
You might need to turn up the pots on the driver chips fractionally
__________________________________________________________________________
Experimenting in 3D in New Zealand
Re: Drift
July 18, 2012 04:33PM
Ok how exactly do I do that?
Re: Drift
July 18, 2012 04:36PM
I have pololu A4988 stepper motor drivers.
Re: Drift
July 18, 2012 07:58PM
There is a small thing on the left of the heatsink that looks like a silver circle on top of a square, it's actually a small potentiometer used to set the current output of the driver.
You can use a small philips or flat blade screw driver to adjust them, clockwise is more current anticlockwise less.
Too much current and the drivers will repeatedly go into protection mode and the steppers with chatter when enabled.
Too little and there isn't enough torque to move the axis.
They do not come set to any sensible value.
They can be very picky about the setting depending on the steppers.
