Anyone recognise this controller? January 06, 2016 10:42PM |
Re: Anyone recognise this controller? January 07, 2016 03:49AM |
#define REPRAP_DISCOUNT_SMART_CONTROLLER
Re: Anyone recognise this controller? January 08, 2016 02:46AM |
Re: Anyone recognise this controller? February 03, 2016 11:35PM |
Re: Anyone recognise this controller? February 04, 2016 09:17AM |
cdunbars
Progress - New thermistor fitted to heat bed - Repetier Host reports Heatbed temp consistent with room temp.
However, in manually turning the heatbed 'ON', nothing happens.
The led indicator associated with D9 of the GT2560 board doesn't light up, as D7 does when the extruder heater is manually turned on.
Where, in Marlin, is the 'switch' to activate the heatbed?
Re: Anyone recognise this controller? February 04, 2016 09:29AM |
Re: Anyone recognise this controller? February 04, 2016 09:58AM |
hoxsiew
Power for the bed takes the path shown in the attached image.
Re: Anyone recognise this controller? February 04, 2016 10:21AM |
Re: Anyone recognise this controller? February 04, 2016 10:35AM |
hoxsiew
The schematic shows that it connects to PWM3. I don't know how that compares with pins in pins.h. I have this board in mine and use the BOARD_ULTIMAKER in Configuration.h with no other modifications to any other files.
Schematic files are here:
[www.geeetech.com]
Re: Anyone recognise this controller? February 07, 2016 09:44AM |
Re: Anyone recognise this controller? February 07, 2016 12:30PM |
cdunbars
As I read it, the schematic shows
PWM3 to be Pin 1,
PWM1 to be Pin 6 and
PWM2 to be Pin 7.
"pins.h" for motherboard "7" (as per the Geeetech wiki)
assigns HEATER_BED_PIN 4.
Bearing in mind
HEATER_0_PIN 2 (not PWM1 "6" as the schematic, and which works when manually activated via Repetier-Host V1.0 RC2)
HEATER_1_PIN 3 (nor PWM2 "7" as the schematic - only one heater connected at D7)
Motherboard fuses intact. Firmware setting or faulty mosfet?
Re: Anyone recognise this controller? February 13, 2016 09:37AM |
Re: Anyone recognise this controller? February 15, 2016 12:48PM |
Re: Anyone recognise this controller? February 16, 2016 01:21AM |
Re: Anyone recognise this controller? February 16, 2016 09:18AM |
Re: Anyone recognise this controller? February 17, 2016 10:48AM |
Re: Anyone recognise this controller? February 17, 2016 02:03PM |
