Hello reprapers,
I'm new to reprap, I'm building the printer but am confused with the endstops and homing.
My configuration is:
X and Z axes are straightforward and endstops are at the least side of the axes.
I want to set up the Y axis to be of right-handed basis to other axes, but the endstop will appear at the topmost side of the axis.
The issue is that the Y-axis homing is not working in this situation.
The endstops have been set up properly and tested, the axes are moving correctly, the X and Z homings working properly. The Y-homing is working if the endstop is placed at the other end but not as I want it to be placed.
Current config:
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR 1
//if Y set to -1, it is working, but the endstop is at the other side (still manually firing endstop will stop homing)
#define Z_HOME_DIR -1
#define min_software_endstops true //If true, axis won't move to coordinates less than zero.
#define max_software_endstops true //If true, axis won't move to coordinates greater than the defined lengths below.
// The position of the homing switches. Use MAX_LENGTH * -0.5 if the center should be 0, 0, 0
#define X_HOME_POS X_MAX_LENGTH * -0.5
#define Y_HOME_POS Y_MAX_LENGTH * -0.5
//if set as Y_HOME_POS = Y_MAX_LENGTH * Y_HOME_DIR * 0.5, the whole axis failes to move until moves 10 cm, to the endstop, and prevents movements back.
#define Z_HOME_POS 0
