Y endstop strange behaviour March 04, 2016 06:51AM |
// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR 1 //if Y set to -1, it is working, but the endstop is at the other side (still manually firing endstop will stop homing) #define Z_HOME_DIR -1 #define min_software_endstops true //If true, axis won't move to coordinates less than zero. #define max_software_endstops true //If true, axis won't move to coordinates greater than the defined lengths below. // The position of the homing switches. Use MAX_LENGTH * -0.5 if the center should be 0, 0, 0 #define X_HOME_POS X_MAX_LENGTH * -0.5 #define Y_HOME_POS Y_MAX_LENGTH * -0.5 //if set as Y_HOME_POS = Y_MAX_LENGTH * Y_HOME_DIR * 0.5, the whole axis failes to move until moves 10 cm, to the endstop, and prevents movements back. #define Z_HOME_POS 0
Re: Y endstop strange behaviour March 04, 2016 01:32PM |
Re: Y endstop strange behaviour March 04, 2016 05:31PM |
