Can you suggest a better way to tighten belts? April 08, 2017 03:44AM |
Re: Can you suggest a better way to tighten belts? April 08, 2017 04:06AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Can you suggest a better way to tighten belts? April 08, 2017 05:50AM |
Re: Can you suggest a better way to tighten belts? April 08, 2017 08:49AM |
drmaestro
Some of the answers to the print quality questions I have posted suggested backlash or not enough tension on belts. Here is how my belt setup looks from top-down view:
[attachment 92780 belt.jpg]
s
Re: Can you suggest a better way to tighten belts? April 08, 2017 03:44PM |
the_digital_dentist
drmaestro
s
You've gone to a lot of trouble and some expense to use linear guides to get high precision, but you have a fundamental error, visible in your photo. The right side attachment where you have locked the belt with zip ties is too high. The belt segments that attach to the carriage have to be parallel to the guide rail at all positions along the rail or the belt tension will vary with the position of the carriage and the prints will be distorted.
The same is true in the Y axis. The belts must be kept parallel to the guide rails or you will have problems.
Re: Can you suggest a better way to tighten belts? April 12, 2017 08:18PM |
Re: Can you suggest a better way to tighten belts? April 13, 2017 03:16AM |
Re: Can you suggest a better way to tighten belts? April 13, 2017 06:52AM |
Re: Can you suggest a better way to tighten belts? April 13, 2017 07:50AM |
While that solution is very common, it introduces elasticity where you usually do not want it. The belts have steel or fibre wires to prevent stretching and to minimize elasticity along the length. Adding such a spring counteracts this intention.Quote
Ed would
At the risk of under-complicating things. . .
[attachment 92951 bspring.JPG]
The simple tensioner spring does a very good job of taking up slack and keeps a positive 'sprung' tension on the belt without needing a mechanically set position of motor/ pulley
Re: Can you suggest a better way to tighten belts? April 14, 2017 09:55AM |
Re: Can you suggest a better way to tighten belts? April 18, 2017 04:57AM |
Re: Can you suggest a better way to tighten belts? April 18, 2017 05:20AM |
It is a matter of mass and acceleration. If you use a core x/y printer with a bowden hotend and normal acceleration chances are you wont see any problems. If you use a Bulldog extruder on a cartesian printer with high acceleration i would avoid a setup like this like the plague.Quote
Ed would
I take you point but I think they are fine.
I only write from a position of personal experience.
The springs do stretch when pulled hard. I don't have anything to measure the force required to deflect per distance so I can't give you any numbers to calculate but I 'feel' that for an average reprap type setup of Nema17/ GT2/ low mass, the spring rate would be enough to overcome the forces applied to it.
I'd be interested if anyone has properly measured it. I'm happy to eat my words.
Ed
Re: Can you suggest a better way to tighten belts? April 22, 2017 07:45PM |
Re: Can you suggest a better way to tighten belts? April 29, 2017 04:20AM |
Re: Can you suggest a better way to tighten belts? May 02, 2017 01:32PM |
Re: Can you suggest a better way to tighten belts? May 03, 2017 04:14PM |
Re: Can you suggest a better way to tighten belts? May 03, 2017 04:29PM |
