Help! Software issues and on a timeline
August 20, 2012 08:21PM
Okay, so after trying prontrface which showed no graphic interface and would only appear as a command line and wouldn't connect to my mendel, I tried replicatorg. This seemed to work until i connected my printer and I couldn't get the mendel profile to work. I tried to adjst the baud rate to 250000 but it still wouldn't connect. I am running sanguinololu 1.3 with sprinter which I got tested with bootloader and firmware tested from botronicz. I really like replicatorg's interface and the documentation but it just won't work! What am I doing wrong?
Bringing 3D printing to America's classrooms.
Follow my efforts at TheChicksNest.blogspot.com
Re: Help! Software issues and on a timeline
August 20, 2012 11:49PM
Well if you want a quick way to get going try repetier --Repetier Host Install Just started working with it and I think it's great!!
I also have the same botronicz board, I ended up putting Marlin on it, but I have had no issues with it so far
HTH
Devon
Edited 1 time(s). Last edit at 08/20/2012 11:53PM by djamwolfe.
August 21, 2012 03:59AM
Try setting the baud rate to 115200.
If you still want to use Pronterface, your probably missing one of the python packages it depends on. You need pyserial, pyreadline and wxPython. Run the software from a command line to get a more useful error message from it.
August 21, 2012 12:32PM
Ooh! Thank you! does repetier need marlin or will it work with sprinter, too?
August 21, 2012 02:54PM
It will work with any standard RepRap firmware, including Sprinter.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
August 21, 2012 04:46PM
I'll go with Andrew on checking the baud rate also, I can't remember if mine was set t 115200 when I got it or not. I do know now I am running 250000 but I think that's set in the firmware.
Devon
