I have finished assembling my Prusa mendel, minus a glass plate and the opto flags. Just for reference i have the prusa mendel i2, ramps 1.4, im using igus 8mm linear bearings, i have 3 opto endstops, an atx 500w power supply( i have hooked up the 5vsb, ps_on/off, and 5v lines), a PCB Heatbed MK2, gt2 belts, with 16 tooth 2mm pitch pulleys(although i also have the 20 tooth pulleys from ultimachine), and a reprapdiscount smart controller.
The build instructions dont really explain what to do after i have built it. But i do know that i will have to change some of the code to be compatible with my machine, like the steps per mm and for the lcd controller, thermistors, and opto endstops, and other things.
The lcd screen i have is only compatible with the marlin firmware, and i have already started to modify the code to work, and i uploaded it to my machine and it works other than the lcd reads the extruder tempurature as 474C, and the buzzer is constantly going off. basically im going to start from scratch again though.
Anyways if you guys could help guide me through the firmware installation process and calibration process, thanks.
also heres a picture, i wrapped all of the wires up using some plastic spiral things.
Edited 2 time(s). Last edit at 09/26/2012 03:38AM by aduy.
