Hi there,
I have had my Prusa Mendel printer up and running reliably for some 6 months now. I have been steadily improving, upgrading and recalibrating my printer with corresponding increases in print quality and accuracy, however I am still having problems with blobbing on layer start/finish. This is getting troublesome as I am trying to print interfacing parts, and I end up with a vertical line up the outside of a shaft, or the inside of a hole, or along a mating surface.
As you can see from the attached picture of the single wall thickness cats, the ridge created from the blobbing at point where the head starts/finishes its layer is quite noticeable. Mostly on the Orange cat, and somewhat smaller on the dark blue (apologies for the poor photo..) so there is an aspect that depends on the filament, however it is still present in every filament colour and type that I have printed with. The circles-towers photo shows that the blob ridge runs up the inside of holes and the outside of the towers.
My Setup:
Makergear Prusa Mendel with 40mm fan blowing over extruder nozzle.
Marlin Firmware
Slic3r (blobbing is present on all versions I've used so far from 0.7.2b onwards)
Pronterface
What I have done:
- Upgraded from Sprinter to Marlin. This improved the quality of the curves, and really drew attention to the layer start/finish issue.
- Tested different filaments. - See pic
- Calibrated my extruder E-Steps for each filament type I use before I use it. My linear dimensions are fine, so Slic3r knows how much plastic to extrude.
- Changed retraction settings (currently using Length: 1mm, Speed: 14mm/s, 0 extra length on restart) - It doesn't seem to be a retraction issue, as it's the start or finish of each layer
- Tested different layer heights (from 0.15 to 0.25) - No change
- Different Print Speeds - The start/finish blob ridge is still present when I vary print speeds
I suspect that it has something to do with a dwell time at the start/end of each layer, and I have tried changing my firmware acceleration settings, however I do now know what a suitable value is. My Marlin acceleration settings for Default_Max_Acceleration of (900,900,50,10000) were copied from the Sprinter firmware that came with the printer.
If anyone has any suggestions I would be very grateful, as I would like to print clean parts which I can use without having to drill out every hole, or file down every mating surface.
Cheers
Edited 1 time(s). Last edit at 11/20/2012 08:44AM by Stamps.
