RAMPS 1.4 endstop error
Posted by prairiewolf407
December 10, 2012 05:38AM
so i am almost there ready to print
i'm running marline and when ever the endstops are triggered it stops the whole printer
it is really starting to piss me off does anyone have any clue about what is happening
Re: RAMPS 1.4 endstop error
December 10, 2012 05:25PM
Check to make sure that the wires are correct. If you hit the home-all-axis function, you should get all 3 axis hitting and endtop. If it is set in the wrong (for example, X motor wiring is reversed, AND you put the endstop on the wrong side) then the endstop will be hit, but the program didnt know what to do. Endstop being hit automatically prevents that axis from being used. To remedy, turn off motors, and move the axis by hand out of the way. Set X=0 manually if you have to for now.
December 10, 2012 09:20PM
i have worked it out now but thanks anyway it was just that the endstop was wired to the +, - instead of - ,S
it makes more sence to me to wire it to +- but i guess not to everybody
