Bridges and Slic3r. May 08, 2013 11:44PM |
Re: Bridges and Slic3r. May 10, 2013 11:58AM |
Re: Bridges and Slic3r. May 10, 2013 01:50PM |
Re: Bridges and Slic3r. May 11, 2013 02:05AM |
Re: Bridges and Slic3r. May 12, 2013 12:34AM |
Re: Bridges and Slic3r. May 12, 2013 11:34PM |
Re: Bridges and Slic3r. May 13, 2013 03:59AM |
Have you tried adjusting your bridge flow rate ? As you set your width manually you might need to adjust that too. A line width of 0.45 seems a bit small for 0.3 layers anyway, that only gives you a WOH of 1.5 which will most likely cause problems with stability of your prints.Quote
0.3mm layer height with a layer width of 0.45 (set manually)
Re: Bridges and Slic3r. May 13, 2013 01:02PM |
