Prusa i3 Marlin Settings? September 26, 2013 11:07AM |
Re: Prusa i3 Marlin Settings? September 27, 2013 02:42AM |
diff --git a/Marlin/Configuration.h b/Marlin/Configuration.h index db02b1d..6111ef6 100644 --- a/Marlin/Configuration.h +++ b/Marlin/Configuration.h @@ -17,8 +17,8 @@ #define SERIAL_PORT 0 // This determines the communication speed of the printer -#define BAUDRATE 250000 -//#define BAUDRATE 115200 +//#define BAUDRATE 250000 +#define BAUDRATE 115200 //// The following define selects which electronics board you have. Please choose the one that matches your setup // 10 = Gen7 custom (Alfons3 Version) "https://github.com/Alfons3/Generation_7_Electronics" @@ -54,12 +54,14 @@ // 301 = Rambo // 21 = Elefu Ra Board (v3) +#define MOTHERBOARD 33 + #ifndef MOTHERBOARD #define MOTHERBOARD 7 #endif // Define this to set a custom name for your generic Mendel, -// #define CUSTOM_MENDEL_NAME "This Mendel" +#define CUSTOM_MENDEL_NAME "That Mendel" // This defines the number of extruders #define EXTRUDERS 1 @@ -135,10 +137,10 @@ // 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup) // 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan) (1k pullup) -#define TEMP_SENSOR_0 -1 -#define TEMP_SENSOR_1 -1 +#define TEMP_SENSOR_0 7 +#define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 -#define TEMP_SENSOR_BED 0 +#define TEMP_SENSOR_BED 1 // This makes temp sensor 1 a redundant sensor for sensor 0. If the temperatures difference between these sensors is to high the print will be aborted. //#define TEMP_SENSOR_1_AS_REDUNDANT @@ -245,7 +247,7 @@ //if PREVENT_DANGEROUS_EXTRUDE is on, you can still disable (uncomment) very long bits of extrusion separately. #define PREVENT_LENGTHY_EXTRUDE -#define EXTRUDE_MINTEMP 170 +#define EXTRUDE_MINTEMP 165 #define EXTRUDE_MAXLENGTH (X_MAX_LENGTH+Y_MAX_LENGTH) //prevent extrusion of very large distances. //=========================================================================== @@ -301,10 +303,10 @@ const bool Z_ENDSTOPS_INVERTING = true; // set to true to invert the logic of th #define DISABLE_Z false #define DISABLE_E false // For all extruders -#define INVERT_X_DIR true // for Mendel set to false, for Orca set to true -#define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false -#define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true -#define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false +#define INVERT_X_DIR false // for Mendel set to false, for Orca set to true +#define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false +#define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true +#define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false @@ -345,9 +347,10 @@ const bool Z_ENDSTOPS_INVERTING = true; // set to true to invert the logic of th // default settings -#define DEFAULT_AXIS_STEPS_PER_UNIT {78.7402,78.7402,200.0*8/3,760*1.1} // default steps per unit for Ultimaker -#define DEFAULT_MAX_FEEDRATE {500, 500, 5, 25} // (mm/sec) -#define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinfo +//#define DEFAULT_AXIS_STEPS_PER_UNIT {78.7402,78.7402,200.0*8/3,760*1.1} // default steps per unit for Ultimaker +#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,237} // default steps per unit for Ultimaker +#define DEFAULT_MAX_FEEDRATE {500, 500, 2, 25} // (mm/sec) +#define DEFAULT_MAX_ACCELERATION {9000,9000,20,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinfor #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts
Re: Prusa i3 Marlin Settings? September 27, 2013 04:51AM |
Re: Prusa i3 Marlin Settings? September 27, 2013 12:23PM |
Re: Prusa i3 Marlin Settings? May 10, 2015 02:32AM |
