I reversed Y-axis, software fix?
October 17, 2013 03:50PM
Hello!
I have reversed my Y-axis, and I forgot untill I was printing some text today...
Reason for why I reversed the axis is that I would like to have motor and power input on the back side of my printer and LCD + USB on the front side.
Wait.
Maybe I can switch it back, but write in the end.gcode to move the Y to max (min is endswitch)? Hmm, i might have found a way...
I wounder, is there a way I can reverse the Y-axis without rotating the stepper wires and moving the end switch over to the other side?
All suggestions are appreciated!
Regards
Edited 1 time(s). Last edit at 10/17/2013 03:52PM by Itek.
Re: I reversed Y-axis, software fix?
October 17, 2013 04:04PM
You can reverse the Y direction in firmware, just change the following line:
#define INVERT_Y_DIR
You can also change the endstop to be at the max instead of min by changing the following line:
#define Y_HOME_DIR
That is assuming you are using Marlin firmware. Others should be similar.
Edited 1 time(s). Last edit at 10/17/2013 04:07PM by NewPerfection.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
October 18, 2013 03:16AM
Yeah!
Im using marlin smiling smiley
Thanks grinning smiley
October 18, 2013 12:59PM
I have tried to change the values now, but the board will not move to home if I change:
#define Y_HOME_DIR -1
to:
#define Y_HOME_DIR 1
October 18, 2013 02:16PM
You will also need to have the endstop plugged into Y max on RAMPS instead of Y min.
October 18, 2013 03:02PM
Ahaa... I didnt know, thanks!
grinning smiley
October 19, 2013 05:08AM
Y axis is still not moving sad smiley
I have changed:
#define INVERT_Y_DIR (from false to true)
#define Y_HOME_DIR (from -1 to 1)
Moved the endstop contact from - to +
My problem in pictures:
[spoiler]
Picture of print before I changed anything (!)
Screenshot of repetier host:
[/spoiler]
Part of my configuration.h:
[spoiler]
//=============================Mechanical Settings===========================
// Uncomment the following line to enable CoreXY kinematics
// #define COREXY
// coarse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
// fine Enstop settings: Individual Pullups. will be ignord if ENDSTOPPULLUPS is defined
#define ENDSTOPPULLUP_XMAX
#define ENDSTOPPULLUP_YMAX
#define ENDSTOPPULLUP_ZMAX
#define ENDSTOPPULLUP_XMIN
#define ENDSTOPPULLUP_YMIN
//#define ENDSTOPPULLUP_ZMIN
#endif
#ifdef ENDSTOPPULLUPS
#endif
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops.
const bool Y_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops.
const bool Z_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops.
//#define DISABLE_MAX_ENDSTOPS
//#define DISABLE_MIN_ENDSTOPS
// Disable max endstops for compatibility with endstop checking routine
#if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS)
#endif
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z true//false
#define DISABLE_E false // For all extruders
#define INVERT_X_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR false//true // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops false//true //If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true //If true, axis won't move to coordinates greater than the defined lengths below.
// Travel limits after homing
#define X_MAX_POS 230//205
#define X_MIN_POS 0
#define Y_MAX_POS 250//205
#define Y_MIN_POS 0
#define Z_MAX_POS 170//200
#define Z_MIN_POS 0
#define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS)
#define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS)
#define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
// The position of the homing switches
//#define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used
//#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0)
//Manual homing switch locations:
// For deltabots this means top and center of the cartesian print volume.
#define MANUAL_X_HOME_POS 0
#define MANUAL_Y_HOME_POS 0
#define MANUAL_Z_HOME_POS 0
//#define MANUAL_Z_HOME_POS 402 // For delta: Distance between nozzle and print surface after homing.
[/spoiler]
Edited 2 time(s). Last edit at 10/19/2013 05:28AM by Itek.
October 19, 2013 12:15PM
Found an easier solution. Changed everything back to original and edited the end.gcode to move the print foreward at the end.
Sometimes its easier to think simply!
