Remember it could always be worse... November 14, 2013 08:06AM |
Re: Remember it could always be worse... November 14, 2013 11:12AM |
Re: Remember it could always be worse... November 14, 2013 12:57PM |
Re: Remember it could always be worse... November 14, 2013 05:42PM |
Aircraft often use the safety wire method of keeping bolts from escaping, I may try a variant of that approach.
Re: Remember it could always be worse... November 14, 2013 06:40PM |
Re: Remember it could always be worse... November 15, 2013 12:39AM |
ikilledkenny
I got to a point where I decided to give up on the threaded barrel and just grip-it and go to salvage the heater block. No such luck even with heat I can not break the two free.
Defeated I resorted to my wallet to fix the issue to find that lulzbot no longer sells replacement parts for my hotend (Version 1.2).
Re: Remember it could always be worse... November 15, 2013 07:38AM |
NormandC
What about this? [www.lulzbot.com]
Granted if it's the threaded barrel and the PEEK isolator you're looking for you're out of luck, but the v1.1-1.3 wooden plates and heater block are still available as replacement parts.
FYI Gadget3D sells a Buda-style hotend clone based on v1.1 and it is significantly cheaper than the Lulzbot one. You might use it for spare parts to rebuild the original (assuming G3D didn't change the specs)...
Re: Remember it could always be worse... November 15, 2013 10:55AM |
