New to 3D Printing. Need Help November 21, 2013 09:23PM |
Re: New to 3D Printing. Need Help November 21, 2013 09:45PM |
Re: New to 3D Printing. Need Help November 26, 2013 03:13AM |
Re: New to 3D Printing. Need Help November 26, 2013 04:31AM |
Re: New to 3D Printing. Need Help November 26, 2013 07:37AM |
Re: New to 3D Printing. Need Help November 28, 2013 09:48AM |
Re: New to 3D Printing. Need Help November 28, 2013 03:00PM |
Re: New to 3D Printing. Need Help November 30, 2013 07:22AM |
Re: New to 3D Printing. Need Help November 30, 2013 01:21PM |
Re: New to 3D Printing. Need Help November 30, 2013 02:20PM |
Re: New to 3D Printing. Need Help December 01, 2013 04:16AM |
dmserve
Are you in control of the motors or are they moving back and forth?
To fix your connecting problem:
Try changing from com 3. Some computers reserve com 1-3 for other uses.
Change to com 4 or above (I use com 9)
Set your baud rate in the computer @ 150000 (device manager)
Set Arduino @ 250000
Set Pronterface @ 250000
This are the numbers that work for me.
Re: New to 3D Printing. Need Help December 01, 2013 09:04AM |
Re: New to 3D Printing. Need Help December 01, 2013 09:20PM |
dmserve
Set up your Com port in device manager first.
(recommend 4 or higher)
_________
Open Arduino
Click on [Tools] in the upper menu
hover over [serial port]
the available com ports will appear to next to it
move over the one you want, and click on it
You can click on [Tools] in the upper menu again to see if was properly selected.
_________
Then select the same com port in Pronterface.
Select Connect.
_________
If Pronterface stalls, not responding, crashes:
Unplug the USB cord
Turn off the 12vdc to the Printrboard
Wait for the Red LED to go out.
Turn on the 12vdc
Plug in the USB cord
Start Pronterface (if shutdown)
Select Connect.
________________________________
Are you using [ Arduino 0222 ] ?
You need to select the following board so the pronterface can connect to the printrboard.
[BootloaderCDC]Teensylu/Printrboard (this file name is all ran together like this)
This is found it the [Tools] of the upper menu of Arduino.
"Board"
I found more info at the makerfarm web site
They had the best information I could find.
On their build instruction page you will find:
PrintrBoard Install - MakerFarm 8-3-12.zip
This information also covers things you may not encountered yet.
They have a good build guide for using a standard ATX Power supply to power the Printrboard.
Not sure a laptop 12V supply has enough wattage to power the printer. (board, fan(s), hot end, heated bed)
Recommendations I have seen talk about 300watts and higher.
Re: New to 3D Printing. Need Help December 01, 2013 10:11PM |
Re: New to 3D Printing. Need Help December 01, 2013 10:50PM |
Re: New to 3D Printing. Need Help February 11, 2021 12:03AM |
Re: New to 3D Printing. Need Help February 11, 2021 01:15AM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: New to 3D Printing. Need Help February 11, 2021 11:29PM |
