Should I fix my hot end or get a new one December 07, 2013 08:31PM |
Re: Should I fix my hot end or get a new one December 07, 2013 08:47PM |
Re: Should I fix my hot end or get a new one December 07, 2013 10:38PM |
Re: Should I fix my hot end or get a new one December 08, 2013 07:41AM |
Re: Should I fix my hot end or get a new one December 08, 2013 09:51AM |
Re: Should I fix my hot end or get a new one December 08, 2013 11:24AM |
Re: Should I fix my hot end or get a new one December 08, 2013 03:40PM |
Re: Should I fix my hot end or get a new one December 09, 2013 07:59AM |
Re: Should I fix my hot end or get a new one December 09, 2013 06:52PM |
Re: Should I fix my hot end or get a new one December 09, 2013 09:29PM |
Re: Should I fix my hot end or get a new one December 12, 2013 10:35PM |
Admin Registered: 12 years ago Posts: 1,063 |
Re: Should I fix my hot end or get a new one December 13, 2013 01:34PM |
thejollygrimreaper
Nununugent:
where did you get the mendel max that the hotend came with ?
the reason that would be jamming is beause the stainless section is too short,
Re: Should I fix my hot end or get a new one December 13, 2013 04:50PM |
Yvan
thejollygrimreaper
Nununugent:
Yes, very much so. I also have doubts about that aluminium "heat radiator".
I've used flat aluminium plates, look at the Eckertech design, it uses the same concept. You want to pull the heat away, not up along the filament feed path.
Re: Should I fix my hot end or get a new one December 14, 2013 08:11PM |
Re: Should I fix my hot end or get a new one December 15, 2013 09:26AM |
Re: Should I fix my hot end or get a new one December 15, 2013 12:52PM |
thejollygrimreaper
Yvan
thejollygrimreaper
Nununugent:
there's nothing wrong with the heatsink , it's being used in a way it wasn't designed and tested for, the stainless is supposed to be a minimum of 10mm between the heatsink and the heater block, in this case the thermal barrier is being used as a heat break which is just wrong
Re: Should I fix my hot end or get a new one December 15, 2013 12:55PM |
Re: Should I fix my hot end or get a new one December 15, 2013 01:43PM |
Yvan
I don't know enough about hot ends to understand what you mean by heat break and thermal barrier?
Yes, the gap is too short, but if there was a horizontal heat sink(where the base of the aluminium cylinder is now) wouldn't it have a better chance of drawing heat away from the filament coming along down the feed path? Right now it seems that the excessive heat reaching the cylindrical heat sink is more than enough to affect the filament on its way down.
thejollygrimreaper
Yvan
thejollygrimreaper
Nununugent:
Re: Should I fix my hot end or get a new one December 15, 2013 02:14PM |
Re: Should I fix my hot end or get a new one December 15, 2013 04:07PM |
thejollygrimreaper
what concerns me and why i asked where the kit came from is because the heat-sink looks suspiciously identical to mine and thats released under a NC license, the other thing is they shouldn't be advertising it in the kit as a jhead
Blomker
All Metal Hot End (0.4mm nozzle diameter. 1.75mm filament)
Re: Should I fix my hot end or get a new one December 16, 2013 02:25AM |
NormandC
thejollygrimreaper
Look at the MM 1.5 kit page on that Blomker site: [blomker.com]
Blomker
But the MendelMax brochure.pdf that's linked in the same page does mention a J-head (with picture). Maybe Blomker used to sell their kits with J-heads and just switched to an all-metal one, and forgot to update the PDF?
The Assembly instructions are very nice. They do show a metal hotend, starting at page 77/108.
Hope you can straighten things out with them!
Re: Should I fix my hot end or get a new one December 16, 2013 07:49PM |
Re: Should I fix my hot end or get a new one December 16, 2013 07:52PM |
