E steps Calibration. Where exactly in the Configuration.h file? December 10, 2013 06:33PM |
// X, Y, Z, E steps per unit - Metric Prusa Mendel with Wade extruder: float axis_steps_per_unit[] = {80, 80, 3200/1.25,700};
#define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 4175.4, 704.033} // default steps per unit for ultimaker
Re: E steps Calibration. Where exactly in the Configuration.h file? December 10, 2013 07:05PM |
Re: E steps Calibration. Where exactly in the Configuration.h file? December 10, 2013 10:36PM |
Re: E steps Calibration. Where exactly in the Configuration.h file? December 11, 2013 02:41AM |
// EEPROM // the microcontroller can store settings in the EEPROM, e.g. max velocity... // M500 - stores paramters in EEPROM // M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily). // M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to. //define this to enable eeprom support //#define EEPROM_SETTINGS //to disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out: // please keep turned on if you can. //#define EEPROM_CHITCHAT
//#define EEPROM_SETTINGSAND
//#define EEPROM_CHITCHAT?
Can you also elaborate a little on that please?Quote
Once you zero in on the correct values, you can write them to eeprom the the cammand mentioned earlier, and you care finished.
Re: E steps Calibration. Where exactly in the Configuration.h file? December 11, 2013 12:29PM |
Re: E steps Calibration. Where exactly in the Configuration.h file? December 11, 2013 06:08PM |
Re: E steps Calibration. Where exactly in the Configuration.h file? December 12, 2013 07:14AM |
Re: E steps Calibration. Where exactly in the Configuration.h file? December 12, 2013 01:04PM |
Re: E steps Calibration. Where exactly in the Configuration.h file? December 12, 2013 08:40PM |
Re: E steps Calibration. Where exactly in the Configuration.h file? December 13, 2013 06:44AM |
Re: E steps Calibration. Where exactly in the Configuration.h file? December 15, 2013 09:54AM |
