First build teething problems: Z-axis out of sync December 13, 2013 07:14AM |
Re: First build teething problems: Z-axis out of sync December 13, 2013 02:33PM |
Re: First build teething problems: Z-axis out of sync December 14, 2013 03:04PM |
#define DEFAULT_MAX_FEEDRATE {500, 500, 2, 45} #define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} #define DEFAULT_ACCELERATION 3000 #define DEFAULT_RETRACT_ACCELERATION 3000
#define DEFAULT_MAX_FEEDRATE {500, 500, 2, 45} #define DEFAULT_MAX_ACCELERATION {450,450,10,10000} #define DEFAULT_ACCELERATION 450 #define DEFAULT_RETRACT_ACCELERATION 450
Re: First build teething problems: Z-axis out of sync December 15, 2013 09:33AM |
Re: First build teething problems: Z-axis out of sync December 27, 2013 05:12PM |
Re: First build teething problems: Z-axis out of sync December 28, 2013 03:10PM |
Re: First build teething problems: Z-axis out of sync December 29, 2013 05:35PM |
Re: First build teething problems: Z-axis out of sync December 29, 2013 05:46PM |
Re: First build teething problems: Z-axis out of sync January 01, 2014 03:35PM |
NEMA 17 Stepper Motor Model 17HS19-1684S - Specifications Frame size 42 x 42mm - NEMA 17 1.8 degree step angle Length 47mm Holding torque 44 N.cm (4.4kg.cm, 62oz.in) Voltage 2.8V Current/Phase 1.68A Resistance/Phase 1.65ohm Inductance/Phase 2.8mH Inertia 68g.cm Bipolar, 4-wire Weight 0.35kg Step Angle Accuracy ±5%(full step,no load) Resistance Accuracy ±10% Inductance Accuracy ±20% Temperature Rise 80?Max.(rated current,2 phase on) Ambient Temperature -10?-+50? Insulation Resistance 100M?Min. 500VDC Dielectric Strength 500VAC for one minute Shaft Radial Play 0.02Max.(450 g-load) Shaft Axial Play 0.08Max.(450 g-load)
Re: First build teething problems: Z-axis out of sync January 01, 2014 03:50PM |
