slic3r issue
January 02, 2014 08:21AM
hi ,
i've got a big problem with my silc3r
it deforms my initial stl file and makes it ugly
have you ever had this error?
please, need help
Re: slic3r issue
January 02, 2014 10:34AM
How big is your STL object?
What version of Slic3r?
Have you checked the STL for errors?
Re: slic3r issue
January 02, 2014 04:01PM
Can you post the STL?
_______________________________________
Waitaki 3D Printer
Re: slic3r issue
January 02, 2014 04:54PM
that's from mesh errors
Re: slic3r issue
January 02, 2014 06:35PM
I agree with all of the above advice, but I would also add that you shouldn't rely on a single slicer. I have toolchains that work with either slic3r, skeinforge, or cura, and at times I have to go to all 3 before I find one that slices correctly. Even if you don't have an integrated toolchain for your less-frequently used slicers, you can still use them and just copy the files around manually. Slic3r handles about 95% of my slicing, but for those stubborn objects that show up once in a while, I go to skeinforge and more recently cura.
Re: slic3r issue
January 05, 2014 10:47AM
thanks for all, i changed the detail resolution in netfabb to solve the problem
now it slices right!
