Printing Problem Please help me
January 04, 2014 09:49AM
Here is my result with that Setting
Printing abs 3mm
Prusa i3
J hot end
Here is my Slic3r Ini Setting
# generated by Slic3r 1.0.0RC2 on Sat Jan 4 09:34:53 2014
avoid_crossing_perimeters = 0
bed_size = 200,200
bed_temperature = 100
bottom_solid_layers = 3
bridge_acceleration = 0
bridge_fan_speed = 35
bridge_flow_ratio = 1
bridge_speed = 30
brim_width = 0
complete_objects = 0
cooling = 1
default_acceleration = 0
disable_fan_first_layers = 2
duplicate = 1
duplicate_distance = 6
duplicate_grid = 1,1
end_gcode = M104 S0 ; turn off temperature\nG28 X0 ; home X axis\nM84 ; disable motors\nM140 S0
external_perimeter_speed = 30
external_perimeters_first = 0
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = .98
extrusion_width = 0
fan_always_on = 0
fan_below_layer_time = 60
filament_diameter = 3
fill_angle = 45
fill_density = 1
fill_pattern = rectilinear
first_layer_acceleration = 0
first_layer_bed_temperature = 100
first_layer_extrusion_width = .9
first_layer_height = .34
first_layer_speed = 30
first_layer_temperature = 210
g0 = 0
gap_fill_speed = 30
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = reprap
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_first = 0
infill_only_where_needed = 1
infill_speed = 30
layer_gcode =
layer_height = .36
max_fan_speed = 25
min_fan_speed = 15
min_print_speed = 10
min_skirt_length = 0
notes =
nozzle_diameter = .5
only_retract_when_crossing_perimeters = 0
ooze_prevention = 1
output_filename_format = [input_filename_base].gcode
overhangs = 1
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_extrusion_width = 0
perimeters = 3
post_process =
print_center = 100,100
raft_layers = 0
randomize_start =
resolution = 0
retract_before_travel = 2
retract_layer_change = 1
retract_length = 0.3
retract_length_toolchange = 3
retract_lift = 0
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 25
rotate = 0
scale = 1
skirt_distance = 6
skirt_height = 1
skirts = 3
slowdown_below_layer_time = 30
small_perimeter_speed = 25
solid_fill_pattern = rectilinear
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extrusion_width = 1.05
solid_infill_speed = 30
spiral_vase = 0
standby_temperature_delta = -5
start_gcode = G28 ; home all axes
start_perimeters_at_concave_points = 0
start_perimeters_at_non_overhang = 0
support_material =
support_material_angle = 0
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_interface_extruder = 1
support_material_interface_layers = 0
support_material_interface_spacing = 0
support_material_pattern = rectilinear
support_material_spacing = 2.5
support_material_speed = 30
support_material_threshold = 45
temperature = 210
thin_walls = 1
threads = 2
toolchange_gcode =
top_infill_extrusion_width = 1.05
top_solid_infill_speed = 30
top_solid_layers = 3
travel_speed = 130
use_firmware_retraction = 0
use_relative_e_distances = 0
vibration_limit = 0
wipe = 0
z_offset = 0
Please Help
Edited 1 time(s). Last edit at 01/04/2014 01:16PM by lclarivee.
Re: Printing Problem Please help me
January 04, 2014 11:35AM
Is this PLA?
Maybe lower bed temperature and more cooling?
January 04, 2014 11:55AM
No it s abs
Does it look like to hot ?
January 04, 2014 12:07PM
I don t know i made 0.5 mm thin wall and came out perfect
January 04, 2014 07:51PM
Those Z mounts look like they've been printed on their sides - they should be flat on the bed.
_______________________________________
Waitaki 3D Printer
January 04, 2014 08:46PM
Just looking at the photo my first guess would be too hot but 210c actually seems too cold. Does the temperature seem consistent or is it jumping up and down? Like maybe the sensor is losing connection and so it tries to make it hotter than it should be. If you use Repetier Host you can see if they temp looks stable or not.
January 04, 2014 09:49PM
I just thought of something, I have never seen ABS that looks quite like that and it's shiny, normally my ABS prints are matt after printing. Is it possible that you actually have PLA and not ABS?
