Ardoino mega shield problem on Prusa I3 February 06, 2014 02:13PM |
Re: Ardoino mega shield problem on Prusa I3 February 07, 2014 06:29AM |
Re: Ardoino mega shield problem on Prusa I3 February 08, 2014 04:27AM |
Re: Ardoino mega shield problem on Prusa I3 February 08, 2014 05:08AM |
Re: Ardoino mega shield problem on Prusa I3 February 08, 2014 09:33AM |
fatihaltunel
Dear friends,
In order to understand the problem, I switched power cables (D8 and D10) of heat bed and hotend. This time hotend was not heating but heat bed was heating. I understood that heat bed has no problem.
1-Power on of my ATX Power
2-Read the voltage at arduino mega shield power input. The two inputs were 12 V. There is no problem.
3-At pronterface, I started heat bed heating. During this start, I measured the voltage at power inputs (only 11A+) of the arduino mega shield. It suddenly dropped to 0 V.
4-At pronterface, I stopped heat bed heating. After that, I measured the voltage at power inputs (only 11A+) of the arduino mega shield. It increased gradually. It took nearly 15 minutes to increase to 12 V.
- Also I looked at the resistance of those big yellow (or green) resistors. Both were nearly 0.8 ohm
Re: Ardoino mega shield problem on Prusa I3 February 08, 2014 09:40AM |
bri857
I am a Newbie, but familiar with electronics. Could others comment on these suggestions as I don't want to get off on the wrong foot !
To load your 12v supply try using old car/motorcycle headlamp bulbs, you can usually solder these. You can also use them to load the 5v supply, but will need more than one bulb. If you have a PC using the same psu type you could try swapping them to test for reliability. Take care, you don't want a broken PC as well !
Re: Ardoino mega shield problem on Prusa I3 February 22, 2014 11:44AM |
Re: Ardoino mega shield problem on Prusa I3 February 24, 2014 09:10PM |
Re: Ardoino mega shield problem on Prusa I3 February 25, 2014 12:35PM |
