Hey guys.
Currently I am building Prusa Mendel i2 with a friend (first time building a 3D printer), using Gen 7 1.5 board with Repetier firmware and Printrun as the G code driver. We've hit roadblocks after setting up frame/electronics/firmware:
- When selecting any value (0.1, 1, 10 or 100) on the control pad in Pronterface in either the X or Y direction, they don't travel in the chosen distance
- There is plenty of stalling in the stepper motor in the Y direction when moving in either direction using the 10mm or 100mm option. Also happens in the x carriage, to a lesser extent.
- Extruder does not heat up nor does the stepper motor in the x carriage work when relevant button is pressed
- Heat bed does not heat up and LED light does not turn on
There are also issues with the endstops and homing of the axes, but these are the major concerns. I've attached the config.h file the printer's using right now. Help in any way would be appreciated.
Thanks in advance!
