How to invert the XY Axis for CoreXY system April 30, 2014 05:47AM |
Re: How to invert the XY Axis for CoreXY system April 30, 2014 05:59AM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: How to invert the XY Axis for CoreXY system May 04, 2014 05:36AM |
Re: How to invert the XY Axis for CoreXY system May 04, 2014 06:26AM |
Re: How to invert the XY Axis for CoreXY system May 09, 2014 11:10AM |
Re: How to invert the XY Axis for CoreXY system May 09, 2014 09:21PM |
Re: How to invert the XY Axis for CoreXY system May 10, 2014 02:27AM |
Re: How to invert the XY Axis for CoreXY system May 10, 2014 09:48PM |
X Y M1 forward M2 forward M1 forward M2 backward M1 backward M2 forward M1 backward M2 backward M2 forward M1 forward M2 forward M1 backward M2 backward M1 forward M2 backward M1 backward
Re: How to invert the XY Axis for CoreXY system May 10, 2014 10:15PM |
Re: How to invert the XY Axis for CoreXY system May 10, 2014 11:10PM |
Re: How to invert the XY Axis for CoreXY system May 12, 2014 05:52PM |
Re: How to invert the XY Axis for CoreXY system September 11, 2014 02:47PM |
Re: How to invert the XY Axis for CoreXY system May 21, 2017 06:09PM |
Hazer
When I setup my HBOT, I had this kind of problem too. Its a bit too hard to explain exactly the way to get it right the first time but what you can do is this:
Plug in one motor backwards and see what changes (make sure motors are OFF before removing and plugging back in).
If that does not work, swap the motor plugs and see what happens.
Then flip the other motor plug backwards. Eventually you will either understand how the driver is trying to work, or you can methodically try each combination and get it right. Trust me, there is one combination that works without changing firmware. There are only 8 combinations:
Re: How to invert the XY Axis for CoreXY system November 30, 2017 09:22AM |
Hazer
Re: How to invert the XY Axis for CoreXY system November 30, 2017 10:37AM |
Re: How to invert the XY Axis for CoreXY system January 12, 2018 04:07PM |
