Pausing a print through gcode in Pronterface June 28, 2014 01:57AM |
Re: Pausing a print through gcode in Pronterface June 28, 2014 02:28AM |
Re: Pausing a print through gcode in Pronterface June 28, 2014 04:41AM |
Initiates a pause in the same way as if the pause button is pressed. That is, program execution is stopped and the printer waits for user interaction. This matches the behaviour of M1 in the NIST RS274NGC G-code standard and M0 in Marlin firmware.Ofcourse if the printer actually paused when M226 was received, the buffer would just fill up and the printer would stop sending acknowledgements to the host program, until the printer resumed, but how would the host program be able to wake up the printer again, if the gcode buffer was full..?!
Re: Pausing a print through gcode in Pronterface June 28, 2014 10:07AM |
Ralf
I'm experimenting a bit with embedding things inside printed parts, and to do that I need to pause the print, at a speficic layer height.
Any other options which I have overlooked?
Re: Pausing a print through gcode in Pronterface June 28, 2014 12:44PM |
Re: Pausing a print through gcode in Pronterface June 28, 2014 04:42PM |
Re: Pausing a print through gcode in Pronterface February 19, 2015 12:46AM |
